Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
My ariens 921 son thro does not advance since i dragged it thru snow banks. the drive train sounds like a train struggling to move, but thats' all..
The auger turns fine, but when i engage the wheels nothing moves forward. is there a belt that could have come off??
  • 433 Answers
Flip it up on its augers, and remove the lower cover and take a look, sounds like you drop a the chain to the axel.
Posted on Jan 06, 2013
Have a gravel driveway bought a Ariens 24 Snow Thro adjusted skid shoes to lift machine, is the scraper blade also adjustable, it is throwing a lot of rocks?
Yes, they are all adjustable. Loosen the hardware, Find something to use as a shim... a few paint can stirrers.. put them under the Scraper to lift it about 3/8" then tighten the hardware. See how that helps the stone throwing. Gravel driveways are tough for Blowers and Plows...It's best to actually leave snow on the driveway to pack down and form a Base. Then the next snow will be stone free.
Jan 07, 2017 | Garden
Why sno thro continues to run after ice block is removed
Because that is how it's designed. It's designed to run again, after you remove ice block.
Apr 29, 2014 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
When in gear right wheel drives left wheel is locked and will not move same when not engaged
Many snowblowers use pins (or bolts - see image below) that pass thru the shoulder of the rim of the tires thru a hole drilled thru the drive shaft. Removing both of the pins allows the tires to spin freely on the drive shaft and makes it much easier to push, pull and turn the snowblower. If they are not installed again, the machine will not "drive" and make clearing snow difficult to do. Installing only one will make the machine want to go in circles. Make sure you have these pins installed thru BOTH rim shoulders and drive shafts - locked in place. Other machines lock the tires in other ways - since it sounds like one side is working correctly - you should compare the two tires / rims and make them both look like the one that works properly. Good luck!
Jan 06, 2014 | Ariens 926054 Snow Blower 2 Stage 32 In
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I bought an Ariens, model #921031 Deluxe 24 with a Briggs & Stratton engine brand new online and haven't used it yet. It's been sitting and now I have a puddle of oil under it. The place t
Some times, the seals not sealed yet not being run. Check all your oil and gear oil levels and run it. Hope everything will be ok then.
Feb 10, 2012 | Briggs & Stratton Garden
Arien Riding Lawn Mower Model A20BH42
Did you check the Hydrostat freewheel control. I can't tell specifically from your question, but it sounds like the freewheel control is set in the freewheel position. See page 12 in the owners manual.
May 10, 2010 | Ariens Pair Of 02483859 Double Sided Skid...
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
How to install spring on Ariens chute
Not a DIY fix as took the snow blower into the shop for them to repair it.
Oct 20, 2009 | Ariens Garden
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
67 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
