Question about IBM Infoprint 1552 Laser Printer
IBM 1552 - Printer Error code 241.10, what does this mean?
4 Suggested Answers
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 18 Answers
SOURCE: My IBM Infoprint 1552 is leaving gray spikes at
Check your toner cartridge (most print quality problems are toner cartridge problems) if that is not the problem (and it probably is) then check the fuser for toner buildup matching the defect you have. There is also a small possibility of the laser being deflected and causing this (unlikely) but clean the small mirror above the toner cartridge (it is small in height and as long as the machine is wide and up in a cavity)
Posted on Apr 05, 2010
  • 11 Answers
SOURCE: I have a IBM 9068
Error 18 is a "Paper Edge Search Error".
1. Check document for damage and check it meets specs.
2. Check that Ribbon Cartridge is installed correctly.
3. Do "Form-Edge Sensor Service Check"
4. Do "Platen" adjustment.
Sensor Status Display:
. Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
3. Press Reject Off button until "4" is displayed.
4. Press Start1 button to shift to next digit.
5. Press Reject Off to display "4"
6. Display should now read "44"
7. Press Start2 button. The LED display indicates sensor status'
8. You will see changes with inserting paper or removing paper.
FORM-EDGE SERVICE CHECK:
Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
With no paper the LED segment is unlit.
2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
a. Form Edge Sensor -46H2648
b. Form Edge Sensor Cable -46H2730
c. Main Card -
1.46H2632 - Serial Interface
2.46H2634 - Parallel Interface
PLATEN ADJUSTMENT:
Posted on Aug 31, 2011
Can't ping the printer and it has a valid I.P. address
Is it a static IP or dynamic? Can you assign a different IP? Do you have permissions set properly to let you use the printer? I presume you have reset everything ... and rebooted ... Can you ping other devices on your network?
Let me know what happens ...
Apr 08, 2014 | IBM Infoprint 1552 Laser Printer
Driver download
Please click support lexmark com to download the drivers.
Aug 08, 2013 | HEWLETT-PACKARD Hewlett Packard 27773...
Having dark black blob spots along the side of every page
it sounds as if your computer screen is going bad replace it.
Jan 25, 2011 | IBM Infoprint 1552 Laser Printer
The machine give code 066 board fail
Don't know what this error code means exactly but going off the word 'board', I would think it would mean there is an issue with the motherboard(s).
If you call the manufacturer of this printer, they will identify what error code 066 means exactly.
Feb 17, 2010 | IBM 4230 Model 102 Matrix Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
Feb 08, 2010 | IBM Infoprint 1552 Laser Printer
I recently changed the toner cartridge on my IBM Infoprint 1552. Now I get a thin smudgy line all the way down the right side of printed materials. I know it needs to be cleaned, but I don't have a manual,...
Chances are you have a smudge on your drum roller... (its the shiny metallic tube). Roll it around and see if can see any foreign materials on it, and wipe it off carefully with a lint-free cloth.
Oct 15, 2009 | IBM Infoprint 1552 Laser Printer
HP LJ5100tn Error 57.1
Error 57.1 means there is an problem with the fan. The fan is at the back of the printer, check that it's not blocked and/or reseat the cable connection into the pwb. If this doesn't work, replace the fan HP part number RH7-1552-000CN
Apr 19, 2009 | HP LaserJet 5100tn Printer
IBM Infoprint 21- 651 HW error
Look in Printer Manual (usually in the back) for error codes.
Try cycling power including unplugging AC cord from printer for 1/2 hour.
Apr 25, 2008 | IBM Infoprint 21 Laser Printer
Resetting IBM infoprint 1552 maintenance counter
Apr 22, 2008 | IBM Infoprint 1552n Printer
IBM Infoprint 1552 Laser Printer Logo
67 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
