Question about Nikon D50 Digital Camera
My photographs are blurry
I want to take a picture without flash and when I manually push "no flash" the image is blurry even though it is very steady. I tried switching the M, S, A with no results. This is a new problem and it seemed to be fine before. The shutter sticks before taking the photo. Could it be mechanical.
  • 3 Answers
Just set the shutter speed yourself. and unless its on a tripod it wont be steady enough.
Posted on Jan 26, 2009
When i take pictures or on webcam with some1 they say im bluryy and i need help so i can see a clear picture of my self no blurry
webcams are not good for taking still photos. they are best for video. and even at that they are not very good quality, their use is for online streaming of video, which they are good at.
if you really want to take a good still photograph with your webcam you should use the application that comes with it, make sure not to move, and make sure the lighting in the room is static, else the camera will keep adjusting which results in a blurry image.
Mar 28, 2011 | Logitech Webcam
Blurry image without flash
A blurry image when the flash is not used usually means that you move when snapping the picture. The flash helps you because the duration is so short, it freezes your motion.
Jan 19, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Canon sd900
Try a higher ISO speed (suggest 400). Look in your camera's instruction book to find out how to do this.
May 27, 2008 | Cameras
Blurry pictures
Most probably you have incorrectly set your camera to a Camera Record mode other than Auto.
If there is not enough light and you are trying to photograph the scene without flash, (eg. by setting your camera mode to a mode that is programmed not to use flash) then the camera has to compensate for the missing light by keeping its shutter open for a longer period of time so as enough light comes into its sensor.
If your hand shakes during that time, you get blurry images.
Check your camera settings. The Twilight scene mode gives you slower shutter speeds to capture dark, night scenes, but you need to stabilize the camera on a tripod or something, depending on the level of light of the scene you want to photograph. The Twilight Portrait, on the other hand, is the same as Twilight with the addition of flash is used to illuminate a person or foreground subject as well as capturing a night background. This mode also keeps a long shutter time for capturing the night background.
For taking pictures of people, I would suggest you use Auto or Portrait mode where the camera will automatically use fast shutter speeds and flash (if dark).
Hope this helps.
May 22, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Virtual tour
the picture is blurry due to lack of focus in the lens.
Im using a fish eye lens. my f\stop is 6.3 shutter is 30.
Im trying to due a virtual tour of my kitchen so its a big picture that i want all in focus. i have tried different settings on my camera but i think im making it worse.
Feb 07, 2008 | Nikon D70s Body Only Digital Camera
Shooting with External Flash
Without more information, it sounds like the flash may be set to a manual mode. Try setting the flash to an auto mode. The display should indicate something to the effect of "E-TTL" or maybe just "TTL". The reason your images are blurry, would be due to a slow shutter speed being used on the camera. If your flash is not set to trigger automatically, then the camera will use the slowest shutter speed to acheive the proper exposure of the image. My assumption would be that if you were to take two images back-to-back with the speedlight set to your current setting, one with the speedlight the other with the pop-up flash, the latter would not be blurry. Hope this helps.
Dec 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
Blurry Image
I had that problem too. So I pushed the MENU button and got to looking to see what all was there. I moved down to where it says SCENE and clicked on it. I moved it down to portrait. On my camera that fixed my problem of no flash and it seemed to take forever to take the picture. You could try that. But I did notice though, that when I turn my camera off and then back on I have to re-do it.
Sep 10, 2007 | Vivitar ViviCam 5100 Digital Camera
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
What should I do if the picture is blurry or out of focus?
Make sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode (2.3" zoomed to wide). When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. On the PhotoPC 3000z you can also use Program (Sports Mode) or Manual (Shutter Priority) to increase the shutter speed. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Nikon D50 Digital Camera Logo
95 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
