Question about Cobra Radio Communications
Howto turn on cobra # 155
Have replaced batteries in grandchildren Cobra model PR155 & cannot find out how to turn on power. Earlier solution indicated to push & hold "menu" button for 3-4 seconds - have tried & still nothing. Any suggestions out there ?
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Ron,
Hmm!
you've been given the correct info, so there is yet another issue with these little TOYS.
They are what they are, Toys, Any one else have any ideas?
Help a friend out Please.
Cheers,
Peter
Posted on Mar 06, 2013
4 Suggested Answers
vrc_tech
  • 109 Answers
SOURCE: Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Posted on Aug 20, 2008
  • 19 Answers
SOURCE: one cobra talk turns on the other does not
Hi Paka,
I think you have aconnection problem, make sure the contacts to the batteries are clean , failing this check the switch and /or clean contacts with crc or a similar liquid,
John.
Posted on Apr 29, 2009
steve132003
  • 98 Answers
SOURCE: I have a set of Cobra Microtalk walkie talkies
Take to Radio Shack they service radios but will charge labor+parts. If you recently bought them take them back and get new ones with your receipt in hand.
Posted on Apr 01, 2011
Aeon cobra quad won't start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
ATV Connection
Thread aeon cobra revo 100cc won start
https://www.tradebit.com/filesharing.php/search/0/aeon+cobra+quad http://www.racingplanetusa.com/index.php?shop_ID=1&sessID=6a91ecd9c6eef46bf7ef3dfc004d97fe&olevel0=2948&olevel1=&olevel2=&level0=4218&level1=&level2=
Aeon Cobra 220 2009
Mar 03, 2013 | Cobra Panther 100 Motorcycles
My cobra 1500 watt inverted doesn't come on wen I
You may not have adequate input voltage. And unless you are hooking up to a forklift battery, the battery will not have adequate current delivery capability for any more than a few seconds at full power of the inverter.
1200 Watts is 100 Amps. 1500 Watts is in the neighborhood of 130 Amps.
Jan 17, 2012 | Cobra Electronics - Others
How do i charge my cobra hand held radio
According to Cobra's website, if you are charging the batteries (or battery pack) that came with the radio, charging should take about 15-hours.
If your model came with the desktop charging stand, they state that it is safe to leave them in the stand without fear of over-charging. If your model uses a power cord that you plug into the radio, then they state that you should not leave it connected to the charger for more than 24-hours.
If you follow the link below, it will take you to the Cobra website, where you should be able to download a copy of the manual for your radio. Find your model in the list, then select the "Details" button for that model. A new page will open then select the "Product Specifications" tab, and you will find a link to download the manual.
Cobra Two-Way Radio Page
Hope that helps you out.
Nov 30, 2011 | Cobra 18-Mile, 22-Channel FRS/GMRS 2-Way...
Need batteries
You can get the batteries at http://www.batteriesplus.com/models/555-0/4077-Two-Way-Radio-Batteries/Cobra.aspx or one of their retail stores. There are other second sources such as
http://www.buytwowayradios.com/Products/Accessories/Cobra-Radio-Accessories.aspx
Please rate this solution. Thanks.
Sep 28, 2011 | Cobra Radio Communications
Cobra MicroTalk. Model No. PR155. Will not turn on. No problem with the battery.
Here is the deal people! Easy fix. When you depress the on/off button on the walkies, keep the button depressed for 3 or 4 seconds. It will power up. The reason why you have to depress the button for a few seconds is because the button has more than one function. Hope this is the solution.
Jan 29, 2011 | Cobra Radio Communications
Need batery for cobra model L14900
You can purchase a compatible battery on eBay for $13.99:
http://cgi.ebay.com/BATTERY-FIT-BK-71216-Cobra-LI-3900-700mAh-BRAND-NEW_W0QQitemZ270509452146QQcmdZViewItemQQptZ2_Way_Radios_FRS?hash=item3efb9eab72
Or get the original through a Cobra dealer for $19.95:
http://cobra.com/index.cfm?fuseaction=product.display&product_ID=283
Jan 02, 2010 | Cobra Radio Communications
I HAVE A COBRA RADAR DETECTOR AND HAVE TO BUY A REPLACEMENT CAR/CIGARETTE POWER CABLE.I HAVE SOURCED A COMPANY WHICH CAN SUPPLY AN 800ma OR 2000ma power.DO YOU KNOW THE POWER CONSUMPTION OF A COBRA MODEL...
I dont know the exact amp rating on the ESD9000 you could probably get away with a 1 amp fused cig plug. Using a cig plug this is basically direct to your battery. You can use any universal cig plug adapter as long as you make sure you have the polarity set correctly, usually on the Cobra radars the center is positive.
May 14, 2009 | ESD-9215 Radar Detector
Lost the manual for cobra radar detector XRS9985
Are you sure that this is the correct model number? I don't see it on Cobra's web site. Some retailers request that Cobra brand their products with different model numbers in order to avoid having to honor any "lowest price" guarantees. Check Cobra's web site and see if your Cobra RD model looks identical to one of the other models shown on their web site. Alternatively, call Cobra and ask them for a link to an online PDF of the user manual or for a replacement manual.
Apr 19, 2009 | Cobra Vehicle Parts & Accessories
Radio Communications Logo
69 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
