Question about Dryers
Im taking out a switch in a four switch circuit
We are remodeling our kitchen we took out a wall and have switches that need too be removed. one circuit for a light has four different switches that operate the same light and the one on the wall we removed has to come out. where do i start?
    Genius:
  • Dryers Master
  • 1,669 Answers
If you are planning to put 4 switches back in after the renovation, you need to make a wiring schematic of exactly how they are wired now and label each wire according to your schematic. Then when you put them back, everything will work. If you are going to use less light switches then the schematic will help with a smaller number of switches. These are 3-way switches, for your information, not regular 2-way switches!
Posted on Jan 02, 2013
Ceiling fan
If you are controlling it with a pull chain switch the switch is likely bad. If from a wall switch the wall switch may be bad or a wiring problem has grounded the light circuit. You probably need a handy man who does ceiling fans
Jan 11, 2018 | Dryers
Tip
Garage Door Home Improvement: Great Suggestions For Sure Success
<br><br>Have you considered adding a brand new coat of paint in your garage door? Because <a href="http://www.garage-door-experts-bonita.com">Bonita garage doors</a> are usually open to the weather conditions, they could soon become quite tattered looking. A new coat of paint helps make your residence look new and more valueable. Try deviating in the normal or drab colors with a thing that will compliment your residence with vibrancy.<br><br>As this article has shown, there are numerous consideration that ought to be thought about before you begin any home remodeling project. In case you have reliable information, home remodeling can be easy. Maintain the ideas in this post at heart, and things goes smoothly.<br><br>You don't need to have a hard time with home repair! If you are planning ahead and look after an adaptable attitude, you will be able to do your own home improvement projects within a timely and cost effective manner. In order to use a smooth, hassle-free exposure to another home remodeling project you take on, just browse the suggestions set out below.<br><br>Before you decide to commit to an alternative paint color for the outside of your own home, spend time driving around and seeking at homes that you prefer the appearance and color scheme of. Paint chips are way too tough to envision, so seeing it face-to-face will help you produce a better decision.<br><br>When removing cabinets as an element of a kitchen remodel, ensure you don't just unscrew and yank them from the wall. You will more than likely wind up taking some or all the drywall off with you. Take some time and care to eliminate each and every screw, and employ a utility knife around the edges to get rid of the caulking which had been probably employed to seal between the cabinet as well as the wall. <a href="http://www.garage-door-experts-bonita.com">garage doors Bonita</a><br><br>Should you don't want to have a toilet that won't stop running, try checking the flapper valve. Flapper valves act as rubber seals to the tank and let water inside and out. Pull the siphon in the tank and examine the valve. If it's dirty, wash it. Whether its broken, replace the valve with a brand new one.<br><br>Talking to a buddy that is a contractor or does other work related to construction can often provide some helpful insights. They will have a great idea of what has to be done for a certain project. They may even be happy to lend a hand for any difficult or tricky home remodeling task.<br><br>Should you don't want to nail pictures to the wall as a result of holes the nails make, a fairly easy option is buying mounting squares. Mounting squares can readily hold some weight and will be quickly removed with no damage to your wall. Stick four squares altogether, one out of each corner of your frame to mount the picture properly in your wall.<br><br>If your house is filled up with old-style brown wooden doors, do not attempt to brighten them on top of paint. The effort involved will not be worth every penny. It might take three or four coats of paint to pay for the brown wood. You're more well off simply purchasing a new white door instead.<br><br>In case you have building materials to save, put them involving the floor joints or ceiling rafters. You can put longer strips of molding and big materials, especially two by fours over these areas. You can actually hammer in furring strips across several exposed rafters or floor joists and put in the material that must be stored.<br><br>An easily-missed aspect in cooling costs will be your AC unit. You may possibly not should replace your insulation or windows, should you simply replace or clean filters with your ac. This is correct both for window and central air units. The price of a whole new filter for the central unit is far less than new insulation!<br><br>Use fruit and flowers to provide fresh energy in your kitchen. Some colorful flowers and fruit really can perk your house up. Your kitchen area will seem brighter and more inviting immediately. Viewing a vase of freshly cut flowers brightens up any day.Use fruit and flowers to provide fresh energy in your kitchen. Some colorful flowers and fruit really can perk your house up. Your kitchen area will seem brighter and more inviting immediately. Viewing a vase of freshly cut flowers brightens up any day.
on Aug 04, 2013 | Safe International New and Improved HOME...
Kird801hss- vent will not raise
I had the filter micro switch problem as well. After disassembling everything and manually raising the vent, I took the micro switch assembly apart and wired around the micro switches so it would not happen again in the future. In my model there are two leads leading to the micro switches and one jumper that provides a common lead to both switches. To wire around them you simply need to run a jumper from one of the leads to the other lead completing the circuit and bypassing the switch. I removed all of the mechanical parts of the switch including the springs and plunger mechanisms and then reassembled switch housing and reassemble the rest of the fan housing etcetera. Everything works fine again and I no longer run the risk of at loose filter causing major disassembly work
Apr 16, 2013 | KitchenAid KIRD801HSS Kitchen Hood
No power to the fan or lights. Checked the
You're saying fan (singular) and lights (plural)? Does this fan and these lights work off of one switch? If so, then it's probably a bad switch. You can check this by turning off the circuit breaker. Remove the switch from the wall, and put the two wires going to that switch together. Make sure to use a wire nut, or tape to keep these wires together without touching and grounding anything. Make sure these wires are clear of anyone or anything, and then go back and turn on the circuit breaker. If the lights and fan go back on, then it's a bad switch. This is what it sounds like. So now, you can turn the cir. brkr back off - replace the switch, and then after everything is secure and the switch is in the off position - you can turn the cir. brkr back on again. Then go back into the kitchen and turn the switch on again to reaffirm that everything is back in working order. If for some reason this doesn't work, feel free to contact me again. Good Luck!  Jim
Mar 30, 2010 | Thermador 30", 36", 42", 48", 60" Wall...
My Kitchen Hood is not working, I need to replace the switch but I cannot remove the cover. There are 3 screws when I took them out I still couldnot remove. Is there anything you can tell me as to how...
i just replaced the square switch myself. DO NOT UNSCREW THE PANEL. YOU CANNOT TAKE IT OFF ALL THEY WAY ANYWAY! Blue tape around the square switch, then take a thin scewdriver and work each side alternating and eventually the switch pops out. These are little plug in switches that just cost $10 but if a repairman has to do it, could cost you $300 - I know, I checked. What a waste of our money to spend almost $1000 on a piece of **** fan!!!
Oct 01, 2009 | Viking VWH3010 Kitchen Hood
'01 Chevy Blazer transmission randomly switches from 2 to 4 wheel
Try this.My Blazer the same.Took the dash switch out, removed the back plate from the switch.Cleaned the four brass contact areas on the circuit board with a pencil eraser, then rubbing alcohol.Re-installed & works perfectly.
Sep 04, 2009 | 2001 Chevrolet Blazer
Ignitor maytag MGR6772BDS gas stove
One of your switches on the gas controls is bad. You'll have to remove the lines from the switches to the ignitor one at a time to figure out which. With the power off, lift the top of the range to expose the controls. There are connectors for the power at each control. After removing one line, turn the power back on and see the result. You'll know when you've hit the right switch. Then, replace it.
Dec 14, 2007 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Dryers Logo
81 people viewed this question
Top Dryers Experts
