Question about Bosch Skil Drill / Driver Kit
I have a Skil 2362 7.2v drill that goes dead when charged
The drill works fine out of the box.. until you put it in the charger for a day or two and then when you try to use it nothing... it is dead.. no lights on the drill, no movement.. If you put it back in the charger the green light comes on as though it has a full charge.. This is the secound one I bought from Lowes with the same problem.. The first one I took back as I assumed the drill was bad.. What is wrong?
  • 1 more comment
  • Anonymous Feb 06, 2009
    I have the same problem.
  • Anonymous Mar 16, 2009
    Me too!
  • joegraves May 08, 2009
    Same here. While on the charger I can pull the trigger and the light turns red. Sending back under warranty, but I've been dissapointed with this drill.
  • 40 Answers
Sounds like the trigger switch is bad. If you know the charger is good and it is charging the battery, then it must be the switch. I suggest you take the charged battery and test it with a multimeter for the 7.2V. If the battery is dead, then check the charger.
Take it back to Lowes and get a different brand.
Posted on May 01, 2009
  • 1214 Answers
SOURCE: how to change drill bit
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Posted on Jan 28, 2009
SOURCE: skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Posted on May 09, 2009
comax
  • 154 Answers
SOURCE: Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Posted on Jun 11, 2009
  • 34 Answers
SOURCE: Power Driver is charged - won't work
If you are sure that battery is fine, problem can be in the switch or brushes. I would check switch first - open the driver, take 2 wires and attach battery directly to motor contacts, in case it works, problem is most probably in the switch. Juraj
Posted on Jul 13, 2010
loud_pipes69
  • 122 Answers
SOURCE: where can find battery for Skil 2372 and 2362
ebay
Posted on Jan 11, 2011
I have a Skil Model 2363 drill. Used it about 3 times. Put it in the charger and it won't charge. I have it for about 1-1/2 years. Skil says I have to buy a new one. That the battery is no longer made....
Sometimes places like Batteries + and the Battery Barn (on line web sites) will have replacement batteries for popular models even after the manufactures quit producing them. That is where I found batteries for my Bosch drill.
Jun 24, 2011 | Skil 2362 02 7.2 Volt Lithium Ion...
Tip
Skil Driver 2336 - how to replace the battery 18650 3.6V
I owned my Skil 2336 driver for a year or two and it appeared to be dead; no power, no charge light. The red LED would come on when you pulled the trigger. I figured it was the battery, but could be the charger. New driver at Sears is $30. I found the battery on Ebay for $8 delivered (actually, the price was for two batteries). OK, let's blow $8 and see what happens. It was an easy fix.
You'll need a small, flat blade screw driver and a solder gun (with flux and solder, of course). The screws look like a small, special Torx drive, but the flat end screwdriver will work fine. Use the screwdriver to remove the four screws, and wiggle the "Skil" cover off (Maybe the other cover comes off just as easy... whatever!). It should look like this:
The battery is exposed. I checked it with a (cheap) volt meter and it reads about 5V DC. Strange, the new battery reads 5V. And by the way, the charger reads 14V DC. Just for the record, I could not get any voltage reading off the two charging connectors at the bottom of the handle, with either the good or bad battery.
Anyway, the battery has TABS. So it's a lot easier to solder in the new battery if you get a battery with tabs. The holes in the tabs are nice, too. The new battery I got was identified as GTL 18650 3.7V 2800mAh and don't forget "tabs".
The Pink wire is connected to the Positive (+) side. The Blue wire is connected to the Negative (-) side. I marked the battery as shown in the next picture:
The tabs on my new battery were longer than the original, so after I soldered the new battery in, I folded the tabs up on each end.
(In hind sight, the new tabs were covered with a black cover. I could have slid the cover off, snipped off the end and slid it back on before soldering.)
Before you put it together, you can try it out. My new battery came with a charge on it. There are two switches; one for the drive motor, and the other for the LED flashlight:
Check for any loose parts laying around and put the cover back on. It can be a little tricky, but it goes back on. Tighten the screws, and put on the charger.... Green light!
4ffc1e0.jpg Speaking of "Green", please safely recycle your battery, and screw"drive" safely.
on Jul 14, 2010 | Skil 2336 02 3.6V 120V Mini Drill/Driver...
My battery will not charge
Supposedly there is , But I don't think so, There is a video on you tube that shows somebody messing with them, I think it is a bunch of ****. Is it the battery or the charger? Do you have other batteries that charge up? The life of the battery is about 1 year. I have boxes full of dead batteries, and guns and chargers. It is cheaper to buy a new gun with batteries and charger than it is to buy 2 new batteries. Check it out.
Jul 11, 2010 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
14.4V Charger doesn't work
This must typically be the Batteries themselves in the Drill. Usually, rechargeable batteries give out after a couple of charges, if it has handled few charges, then it must be a fault within the Charger. But I'm sure a battery replacement would be fine :)
Apr 02, 2010 | Skil 14.4 volt Drill with Built - in Stud...
Both batteries show full charge but don't last 10 minutes. Only had the tool for less than a year.
rechargeable batteries can build a memory, if you use it say for 5 minutes and then put it back on the charger - then the next time you use it for 5 screws and put it back on the charge - see where I am going
Over time the rechargeable batteries "learn" they only have to work for 5 minutes ( dang my son was that way)
You need to fully drain them and recharge them fully several times might take 10 times.
We have a program in our shop that when you are done with a battery it goes in the flashlight until dead, dead, dead then to the charger. I have batteries that are 10 years old and still work almost like new.
You may have to replace yours but it is worth a try
Mar 09, 2010 | Makita Cordless Impact Driver Kit
Charged it and it stopped working
Here is the link to Skil. http://www.skiltools.com/en/CustomerService/ServiceCenters/
Call them and see what they recommend that you do. They will want to keep you as a valued customer. Regards, Joe
Jan 25, 2010 | Skil 2362 02 7.2 Volt Lithium Ion...
My skil drill with 14.4 battery will not work on drill and light will not go on on charger. Battery charger left plugged into outlet for days, is this okay?
no it is not recommended that you leave it plugged in for much more than it takes to charge the battery ,which incidently i think you will find to be u/s it may not be,just not being charged.your tool store will be able to test them. if it happens they are stuffed ,in that range it will cost more to re place those things than to buy anew one good luck
Aug 11, 2009 | Drills
My SKIL 2362 will not work
Try the link.It's a PDF file for the tool you have.It will explain what you should do to store the tool and take care of it.Most likely the battery is no good and you will need a new one
Jun 19, 2009 | Skil 2362 02 7.2 Volt Lithium Ion...
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Skil cordless drill model 2362 - won't charge
Mar 30, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Bosch Skil Drill / Driver Kit  Logo
410 people viewed this question
Top Bosch Drills Experts
John Trevino
River bottom
paulcarew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
