Question about VeriFone VX510
Lost carrier After attempting a transaction and receiving "invalid store #313" message, on second attempt, then received "lost carrier" message. Have tried again several times, and still receive "lost carrier" message.
On my 1999 jeep wrangler [2.4L- 5spd] a circle w/a key in it appears on the upper left of the dash & it will start/run for a few seconds then shut down
i would think that it is an immobilizer symbol letting you know of a problem with the key in use
talk with a service dealer or have the fault codes read to see if there is an immobilizer fault
Nov 08, 2015 | 1999 Jeep Wrangler
Iphone is dead wont charge and wont stay on more than 3 seconds.
Something like that happened to me and I Had to sync it to iTunes and restore to factory settings my only problem was the last time I backed up my phone was in August the yr before so all my new data was lost :( but phone worked after that
Dec 17, 2011 | Apple iPhone Smartphone
I keep receiving "502 Bad
You either have no data plan or your phone's WAP/internet settings are incorrect.
Can you browse the web on your phone? Send MMS (picture/video messages)?
A quick call to your carrier is all it takes to get them to send the settings to your phone. They can also run you through step by step what the settings are.
May 16, 2011 | Samsung Rant Cell Phone
Hi, can u pls unlock my phone(nokia 1800) it is locked with virginmobile. its imei no. is 355386/04/747089/7
you can get the code and instructions for nokia 1800 mobile from here www.theunlockspot.com and unlock it easily from network lock.....,.I also got the unlock code for my mobile at here and unlocked it successfully ...
May 07, 2011 | Nokia Computers & Internet
Paypal has closed my claim because of an invalid tracking number. (see below) I checked with the post office and the number is not invalid. The parcel is "in transit - last logged out of Newark, NJ...
From the sounds of that it looks like you were scammed by someone.
You can open your paypal account and open an investigation as well they do have an insurance policy which you may be able to get some of the money back of not all of it. They will track the e-mail and the account and get it back since you did not receive anything in return.
May 03, 2011 | Watches
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
"Invalid email address": I am able to receive
I recommended contacting them, there is something wrong with your account. also take a look at this https://www.facebook.com/help/?faq=14086&ref_query=email, good luck and remember to vote!
Mar 17, 2011 | Facebook Social Network
With my verizon, i attempted to send a text message to someone but as my phone said it was sending a screen popped up saying "Message sending failed." This has happened to me probaly about ever...
hmm, the only way you won't be able to send messeges, and receive that notification is 1. you have bad reception, 2. the phone you sent it to has your number blocked. 3. your phone is using an incorrect carrier sim card.
Aug 21, 2017 | Verizon Communications HTC XV6800 Cell...
Ntldr cd boot fault
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again
Mar 31, 2010 | Computers & Internet
Razar v3xx
When you receive the message with id and password, it usually means that either your phone is not multimedia messaging compatible or your account is not provisioned with the actual multimedia messaging feature itself.
If unable to send or receive a picture message (MMS), troubleshoot accordingly:
  1. Attempt to connect to MEdia Net on the device. Connectivity to MEdia Net confirms the device has enough signal strength and GPRS availability to send and receive MMS.
  2. Verify MMS is being sent to an AT&T subscriber. If MMS message is being sent to someone other then an AT&T wireless services subscriber, verify that the carrier is supported.
  3. Picture messaging settings are pre-configured on all devices purchased from AT&T. If the settings have been altered or if the device was not purchased from AT&T, validate picture message settings are properly configured.
  4. Attempt to send an MMS again.
  5. If further assistance is required, please contact Customer Care.
If problems occur, please perform the following troubleshooting steps:
  1. Verify device has signal strength.
  2. Check for a GPRS attach on the device.
  3. Verify the browser settings are correct.
  4. Clear the browser cache.
  5. Power cycle the device (turn off and back on).
  6. Attempt to access MEdia Net again.
  7. If unable to access a particular MEdia Net site, check to see if the site is supported by AT&T.
  8. If problem persists, please contact AT&T Customer Service for wireless customers.
Jun 08, 2008 | Motorola Mobility RAZR V3
VeriFone VX510 Logo
80 people viewed this question
Top VeriFone Retail Supplies Experts
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
