Question about 2wire 2700HG-B Router (2700HGB)
Can the 2701 HG-B handle 6000-plus Kbps?
Internet provider has upped speed from 2400 approx. Kbps to 6000 approx. Kbps without changing the router. Will the 2701 HG-B handle this or is it like going from fiber optics at a node to copper wiring to the PC?
    Problem Solver:
  • 15 Answers
According to the setup screen, it can handle DSL link speeds up to 10692kbps (down) and 1036kbps (up)
I can't verify that it works, but... that's what it says
Posted on Feb 11, 2013
sandrew
  • 2961 Answers
SOURCE: 2 wire 2701 router
assuming all the settings (PPOA/PPOE etc) are correct and as long as you know you have got a broadband connection and it's not your service providers fault, check the you dont have a line fault then unplug the router for 30 seconds or so and try again.
Posted on Sep 09, 2007
SOURCE: ATT 2wire 2701 HG-DSL lite on, but bad connection
I've had this problem several times. The last time they sent a tech out and he put a splitter in the box outside to send a dedicated signal to the jack the dsl is plugged into. No problems since. He said I was 19,000 from their signal and that was too farso I was receiving a weak signal. Mike
Posted on Jun 28, 2008
SOURCE: 2WIRE 2701 router
You must log on to the browser interface of the router (usually for 2wire they use 192.168.1.254) run the set up wizard it will come to a screen which asks for a key code, this key code is provided by your ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
Posted on Aug 06, 2008
SOURCE: 2wire058, mod 2701 HG-B
To akd56 - tks for yr earlier advise, I got as far as "connect to a network" which asked for my security key / pass phrase when setting up which I now forgot.
Posted on Nov 20, 2008
dvrsetup
  • 43 Answers
SOURCE: Q-See System Not Listed in available computers
http://www.portforward.com/qsee/
Choose the model of your Q-See DVR and then select the model of your router.
Posted on Jan 18, 2009
I am using tp link td-w8901g router.my internet speed is of 384 kbps for which i have to be able to download at maximum 48 kbps. when i use internet normally, i am having slow browsing. the download speed...
If you are paying for a downlink speed of 384 Kbps you should be getting at lease around 300. First bypass your router - connect your cable/DSL ethernet line directly from the modem to your PC. Go to http://www.auditmypc.com/internet-speed-test.asp run the speed test and see what your download speed is.
If it's less than 300 call your service provider & ask them to check out your line. If they say that you are getting 300 Kbps or more, you have a problem with the ethernet card in your PC. Replace it.
Of course, if your speed is OK when you bypass the router, you have a router problem. Contact the manufacturer or replace it.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 30, 2011 | TP-LINK TD-W8901G Router
In my office we have linksys RV082 as our internet router, we use VSAT C-Band type with 1.5 Mbps ratio 1:4. The problem is when we try to test internet speed from client (Modem ->Router RV082...
I think that this is a configuration issue, which can be resolved by re-configuring the router.
Please refer to the Product Manual for details about configuration and management of bandwidth.
Hope it helps!
CreativeTECH
Nov 25, 2010 | Linksys RV082 Router (RV082-AU)
Changing channel on router
hi....
to change wireless channel of your 2wire 2701hg youjust need to access its default gateway 192.168.1.254 type it on your address bar using internet explorer and you'll see network at a glance page. click on home networking tab at the top and look for subtab written in blue click wireless settings. you'll seewireless name and under that you'llsee wireless channel you just need to pick the channel that you want to use...
Sep 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Is the DWL-520 Wireless Adapter compatible with the 2701 HG modem
The 802.11b and 802.11g Wi-Fi networking standards are generally compatible. An 802.11b router / access point will work with 802.11g network adapters and vice versa.
There is no such conflict reported with the above devices. But as suggestion use an 802.11g wireless card with the Bell as it would give you better performance
Thanks for using Fixya
proton
Jul 27, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
I have a 2wire 2701 hg-b modem,it wont let me get on the internet,it says that tcp port 80 wont let it get on,something with the firewall?is there any way i can get around this and get online?
Try restoring it to factory defaults and start again with securing your network, document every change you make that way you can come back to it and see what change you made that might be affecting your internet access
Mar 29, 2009 | 2wire (1000-400108-001) Router
Dsl
try opening a port your pc via the firewall on your router.
Jul 14, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Wireless routers
If your connection without the router is only 30 mbps, the speed with which you will connect will never be greater than 30 mbps. Adding the router adds latency, so yes a router will always slow your internet connection slightly. 11 mbps is still pretty fast considering when you are downloading something from a website the average speed is about 270 kbps. My wireless router connects my laptop at 54 mbps, it is a wireless N router, which is faster than a wireless G. That could be another factor.
May 07, 2008 | Linksys WRT300N Wireless Router
3 PC's networked to BEFSX41 very slow accessing internet
sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Oct 14, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
In my new router getting less speed in wireless connection than when connected with a cable.
The 54 mbps refers to the stream rate from the router to the wireless reciever, the 100-110 kbps you refer to is the connection speed to the internet. These are two different things, if you were transfering files from one pc to another it would transfer at a max speed of 54 mbps. If you connect via a cable it would be 100 mbps. Your internet speed depends on your isp server your downloads will be less than 256kbps, with even less upload speed.
Dec 19, 2006 | D-Link AirPlus DI-524 Wireless Router
2wire 2700HG-B Router (2700HGB) Logo
154 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
