Question about Philips 170B5CB 17" LCD Monitor
LCD monitor flourescent lamps
Need a supplier of these flourescent lamps for this philips_170b5cb_black_17_lcd_monitor in New Zealand please, any leads regarding this? Thanks Mark
  • 170 Answers
Http://www.philips.co.nz/
Posted on Jan 19, 2009
Monitor went dark after working fine for some time
is the power light blinking or turned orange? If so, the power supply needs to be repaired. If not, the flourescent lamps are burned out.
Feb 24, 2014 | Envision En7750 17" Lcd Monitor - White...
I have a Dell E173FP 17 inch Flat Panel LCD Monitor. About two weeks ago after having turned it off at night (leaving the PC on) then turning the monitor back on in the morning it would light up to half of...
The monitor can be repaired - by replacing one or both the fluorescent tube and inverter. You can have the work done for you - or you can attempt it yourself. Lamp prices vary based on size - but most hover in the $10 range. Inverters can vary in price too - but run more than lamps for the most part. There are numerous suppliers for these parts such as this and instructions about how to do it such as this.
I hope this helps! Please rate my reply - thanks!
Dec 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Philips LCD 170S Backlight problem.. only turns on 1 second and than the backlight goes off..... which component at the power supply board i can replace it?? thanks
It can be DC filters caps with leaking/bulging tops, or they have high ESR, bad transistors or IC or transformers in the backlight inverter circuits, bad lamps assemblies. Please read below and look at the pictures of bad caps, failed monitors, and troubleshooting guides.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 08, 2010 | Philips 170S6FS 17" LCD Monitor
My monitor is 170s black 17" it switches on and off with different delays of time sometimes it works for 5-10 minutes and again switches off by itself, pressing switch sometimes works sometimes not....
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 19, 2010 | Philips 170S4FB 17" LCD Monitor
Philips 170V LCD screen steadily blinks on and off, even when not
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 13, 2010 | Philips 170V6FB (Black) 17" Monitor
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Repair of LCD (17")
how much does it cost me to repair my brocken lcd??
Sep 03, 2008 | Computers & Internet
CTX VL701 16" Monitor
I made contact with US supplier and am waiting for part reference number.
Thanks
Geoh
Jul 24, 2008 | CTX VL701B (Black) 17 in.CRT Conventional...
Computer says disk boot failure when I turn it on.
hard drive failed or you have a cd in or floppy in the drive.
Jan 07, 2008 | Philips 170B5CB 17" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Philips 170B5CB 17" LCD Monitor Logo
117 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
