Question about Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER
I can't get my Toshiba laptop to see my N Ultra Linksys wireless router....says it cannot find any wireless networks. Whats wrong?
  • 3 Answers
Where you from
Posted on Jan 19, 2009
I currently have 2 sony computers connected to my Linksys WRT310N Router. I just bought a new Dell Laptop for my home business and I can't get it connected.
I'm assuming your new computer uses Win 7, so try opening Control Panel, Network and Sharing Center - then elect to set up a new wireless network. You should 'see' your wifi network - if not, then come back with that info & we'll take it from there...
May 03, 2011 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
I HAVE AN ACER LAPTOP WORKING OFF A LINKSYS ROUTER AND NOW WOULD LIKE TO ADD MY NEW TOSHIBA LAPTOP. HOW DO I DO THIS, KEEPING IN MIND THAT MY TOSHIBA IS NOT CONNECTED TO THE INTERNET
Make sure that the wireless is turned on, on the laptop. Then go to network settings and veiw wireless networks, or if your running xp double click on the wireless signal on the bottom right corner. Click on your wireless sigal and hit connect and that should be it.
Apr 13, 2010 | Linksys Wireless-G WRT54G Router
We have a new laptop, and desktop and a linksys
by default all laptop has wilreless adapter inbuilt in it
but desktop doesnot have wireless adapter
if you have wireless adapter on all laptop and desktop
in that case
reconfigure wireless setting of router
changed ssid and network key
regards
prakash
Mar 14, 2010 | Linksys Computers & Internet
Router hookup
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
Customize the Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
CAN'T CONNECT TO WIRELESS ROUTER WITH LAPTOP.
Temporarily disable all security on the router AND your laptop wireless card and try again to test connectivity.
The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
This is caused by setting the encryption to WPA-RADIUS instead of WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it should30924e8.jpg work.
Also check to make sure that IEEE 802.1x authentication on the wireless network properties Authentication tab is disabled.
Jan 04, 2009 | Linksys WRT160N Wireless Router
Toshiba WRC 1000 as a Wireless bridge
lets get the picture right. laptop connects to a wireless router. then u want to plug into laptop ethernet wan port of linksys ? you have to set router manual settings to gateway which is ip of toshiba... this is a fun topic. ive connected xbox360 to laptop this way.. never tried router. "fun times ahead!"
Oct 10, 2008 | Toshiba WRC 1000 Wireless...
Wireless linksys
If the setup CD is not working fine for you , It will be better for you to call the Linksys tech support and they can walk you through wtih the process on how to manually configure the router and set it up as a Home network, this is the Linksys phone number 800-3267114...
Hope that helps.........
Aug 11, 2008 | Linksys Wireless-N WRT150N Router
No connection to desktop, but great connection to laptop???
Hi Lindsay,
The very first thing that you need to do is to personalize the wireless settings of your ultra range plus router. Since your laptop is wired directlty to the router and is working properly, you can access the router's GUI to personalize the wireless settings. Open internet explorer on the working computer and type http://192.168.1.1 on the address bar, you will be prompted to enter a username and password, by default there is no username and the password is "admin" if you have setup a password using the setup cd then use that one.
Now your inside the setup page of your wireless router, look for the tab the say's Wireless and below you will find four sub menu namely; Basic Wireless Settings, Wireless Security, Wireless Mac Address and Advance Wireless Settings.
Under Basic wireless settings change the Wireless Network Name(SSID) to something you prefer(this is a must).
For the Radio Band, set to Wide 40Mhz. Wide Channel(9), Standard Channel(11) now click on "Save Settings".
Now got to Wireless Security and for the Mode choose(WPA Personal/PSK Personal) Enter a 8 or more digit password under passphrase and click "Save Settings".
Now your done setting up your wireless router it's now time to connect your desktop wirelessly.
If your using a linksys wireless usb network adapter more or less you have also installed the WLAN Uiltility but personally I use the built in WLAN of XP and Vista.
Using the linksys WLAN Utility for to the Profiles tab and highlight default.
Click Edit and it will provide a list of available network(SSID) that your computer detects.
Select the name(SSID) that you provided the router earlier and click connect.
It will not prompt you to enter the WPA Key also known as passphrase(remember the 8 or more digit password) then click Connect to the Network.
You should now have a valid internet connection wirelessly on your desktop.
Oh and for your 2nd question the answer is No, since you already purchased and installed a wireless usb network adapter for the desktop computer you don't need to purchase a long ethernet cable or move the desktop to where the route is.
Hope this will help you get connected.
Regards
Jul 23, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT ROUTER Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
