Question about Thermador HDW36TS Stainless Steel Kitchen Hood
S80-40ARP7701UL kitchen hood-light switch doesn't work
When i tried to turn the light off, i noticed the light switch was loose and quickly realized it had broken. I had to manually unscrew the bulbs to turn the light off. Is there a was to replace this switch, bec. otherwise everything else works perfectly fine.
Reverse Light doesn't work, fuse good and bulb to.
I haven't worked on an escape, but i can tell you that switch is on the transmission.
Jun 02, 2013 | 2010 Ford Escape XLT
Front turn signal works but the running light doesn't
Hi Anonymous, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below: Harley Davidson Wiring Diagrams and Schematics
Sep 03, 2012 | 2010 Harley Davidson FLHX Street Glide
I have a 2000 chevy silverado 1500. 3 nights ago, my truck started up just fine with no problems and has never had a problem starting up. The next morning, I tried to start it and the dash lights and radio...
do you have remote start on that truck? if you do, it has a hood safety switch that will keep it from starting if hood is open. That hood switch is quite easily identifyable. Look for it on the drivers side, either close to the firewall or right at the front of the fuse box.itsa worth taking a look
Aug 12, 2011 | Chevrolet Silverado 1500 Cars & Trucks
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
Replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Feb 08, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
How do you take out light ballbs from dacor hod fan
To replace the light bulb:
1. Remove the right filter and turn off the main power
switch.
2. Gently push the suction cup on the light replacement
tool A (provided with you range hood)
onto the lens of the light bulb B .
3. Turn the tool counter-clockwise until the bulb
comes loose.
4. Remove the tool from the bulb and put it on the
lens of the replacement bulb.
5. Screw the new bulb into the light fixture clockwise
until it is tight. Turn on power at the fuse or junction
box. Turn on the main power switch and touch
the light key to make sure it is working.
6. Replace the filter.
You can download the manual here.
Good Luck And please Rate FixYa!
Dec 19, 2008 | Dacor EHD3618SS Kitchen Hood
The lights dont turn off anymore
On line....sound control board to me...
Dec 29, 2007 | Jenn-Air JXT8136ADS Kitchen Hood
Vicking VIDV500 Kitchen Hood
steve...first, is the light working? If not, you may not have power. If so, turn off all power to the unit at the breaker. Remove the filter and see if the blower turns easily by hand. Yes...switch could be bad...no...motor bad.
Open up unit and using test light from the hardware store and motor plug disconnected...turn on fan and probe the motor feed wire for power. It may be the switch that's bad. This should tell you.
Dec 01, 2007 | Viking VEDV900 Kitchen Hood
F90 st.steel hood fan problem
kerry, does it make any difference if you hold that button or not? If so, the switch set could be bad. Any odd noise from the motor? The motor might be bad. Power off. Then, remove the filter and try to turn the motor by hand. If it turns hard, it's the motor. Easy, then replace the switch. Check the electrical connections to the unit. There should be a box somewhere inside the housing. It is possible that wires have come loose. Again, do this part with the power off.
Nov 25, 2007 | Baumatic F60 Stainless Steel Kitchen Hood
Thermador HDW36TS Stainless Steel Kitchen Hood Logo
151 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
