Question about Packard Bell 1580509280 Network Adapter
Easynote e4700 rj45 port is dead
Rj45 LAN interfaces has stopped working. Router shows no connection. Cable replaced and router port switched to no avail. System shows port as active. OS is Linux Centos 5.5. LAN connection has been working for about two years under same evironment without problems until yesterday. Thanks in advance.
    President:
  • 623 Answers
  1. Did you ping 127.0.0.1 to test the computers own basic network setup?
  2. Did you do a yum update and the network driver was updated?
  3. Did you check service network status?
  4. You could also update to at least 5.7 for better network support.
  5. It seldom happens, but network cards do die. This usually happens out of the blue with no forewarning. The only way to tell is to put the card into another computer and/or to replace the existing card. Good thing is, they are really not expensive.
Hope this helps, otherwise let me know.
Posted on Jan 03, 2013
I have rj11 router bur i have rj45 internet cable . how to configure???
First of all a RJ11 plug is used for a phone line. That router has 4 RJ45 ports as well & which you will use. So forget about the RJ11 plug.
There will be a special port (RJ45) were your modem will plug into. It should be clearly marked. Then use the RJ45 cord connected to you computer to your router.
Use the CD will the router to set up.
Advance users goto your web browser & in the address bar type: 192.168.1.1
The default username and password are both admin in lowercase
A setup screen will load.
P.S For the wireless security use WPA 2 Personal
Feb 21, 2013 | TP-LINK TPLink TDW8950ND 150Mbps Wireless...
If i dont have the cd to set my router up what do i do
remove the rj45 cable c2bda4d.jpgof your router then reconnect to the lan port found at the back of your PC. then you will have internet connection. After that download the latest router driver found at the manufacturers website. After that you may now return the rj45 cable to your router. Happy surfing!!
Sep 01, 2010 | Computers & Internet
How do you connect a netgear router from dsl to cable
The DSL modem will have a LAN port (RJ45), plug a LAN cable in this port and connect the other end to the Netgear router's WAN port.
Sep 10, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
DL-634M Wan socket
Try to update the firmware of the router first and hard reset it.
To hard reset it, press the reset button at the back of the rouetr for 30 secs then unplug the power for 30 secs and then plug it back in. Check if that fixes it.
Jul 05, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Belkin mimo installation
what you should have purchased was a modem/router and not a seperate router to connect to your modem, but the modem should connect to the cable/adsl port (wan) using the initial RJ45 lan cable, and then a lan cable from one of the 4 ports on the rear to each pc.
Sep 24, 2007 | Belkin (F5D5231V4-SN-PD) Router...
Wireless G Router
you should have the cable modem connected to your routers WAN port, using the lan connector cable (RJ45 plug), then using another lan cable from the router number 1 port to your pc's network lan card, making sure the uplink button is not pressed in as this is if you wish to use more than one router on your network. Go to control panel, network connections, right click on your network card>properties, then click the TCP/IP line and again click properties, then select 'obtain ip address automatically'. go to your web browser then type in 192.168.2.1 which should take you into the router settings and look for DHCP clients and make sure DHCP is enabled and save settings. Restart the pc and it should now connect.
Sep 01, 2007 | Belkin (F5D5231-4) Router
Router connection
the cable modem lead should plug into the internet socket, then a lead rj45 should come from any of the other 4 ports to your lan network card in the back of your pc and thats it, all the settings will be the same as before.
Jun 06, 2007 | Linksys EtherFast Cable/DSL Router with...
Packard Bell 1580509280 Network Adapter Logo
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
