Question about Thermador PC366BS Stainless Steel Gas Cooktop
Need to convert back to city gas
I know the tips have to be replaced, what size socket will I need, and will I need a regulator?
  • 979 Answers
The gas co. Should do all this for you. They will be glad since it will give them more business.
Posted on Jan 30, 2013
It takes several minutes for the igniter to light the GE cooktop burners.
Mike, do the flames look to be normal size once they do light or are they very small? You may have a bad regulator. The regulator is used to lower the incoming pressure to a safe level to prevent excessive flame size. It sounds as though the regulator is not working properly. However, if the flames are small or uneven levels, check the orifices directly below the caps or on the burner valves for any obstruction such as spillage or cleaner residues. You can replace the regulator with any brand that has a 1/2" in/out pipe thread. Most are available at a large hardware store.
Feb 01, 2016 | GE Cooktops
New cooktop ! long flame yellow tips black deposits on pans
This is probably the result of inefficient burning of gas resulting in sooty deposits being left on the base of saucepans etc. It may be that the gas jets are blocked with spilt material and need cleaning. Try removing the gas hub with the gas jet holes in and sliding a paperclip sized rod into each hole to dislodge any material. Blow in the holes afterwards to force any loose material out. If this fails you may need a gas fitter to adjust the gas mixture regulators.
Nov 03, 2013 | Smeg 23 in. SE64 Gas Cooktop
Flame size will not regulate. Authorized Jenn-Air repairman came out and replaced the regulator and I still have inconsistent flame size on all four burners. About 1/2 the time it's like it's...
What other appliances work on gas? The furnace? The water heater? A gas dryer? How much propane is in the tank? I wonder how the cooktop would work on a seperate tank? If it worked perfect on another tank I would say you have a plumbing problem.
Oct 26, 2011 | Jenn-Air JGC8536 Gas Cooktop
The regulator seems to be closing off completely, and not flowing gas (LPG). We have converted cooktop from natural gas to propane per instructions manual -- changed orifice spuds, converted regulator and...
I HATE TO TRY AND EXPLANE THIS FOR FEAR SOME THING MAY GO WRONG DID YOU FOLLOW THE INSTRUCTIONS TO THE LETTER. FROM NATURAL GAS TO LP YOU SHOULD OF HAD TO CHANGE THE POSISTION OF THE ORVICE IN THE REGULATER THAT IS WHY YOU ARN'T GETTING THRU THE REGULATOR CHECK YOUR DIRECTIONS AGAIN SOME TIME YOU HAVE TO THIGHTEN THE NUT ON THE REGULATOR SO IT DISTORTS THE ORFICE TO LP, AND SOME MODELS YOU HAVE TO TURN THE ORFICE OVER. BECAREFUL AND TRY AGAIN
Feb 06, 2011 | Maytag MGC5430 Gas Cooktop
Intalled the 30" gas oven, converted to LP (both
Hello, thank you for posting. It sounds like you have done a little work to get the unit converted to LP. Make sure you didn't install the regulator upside down. Sometime you can get a defective regulator out of the box. Some of the regulators have the "N" for natural gas if so you need to convert this as well. I suggest you send a factory repair person just to double check on the unit. It well not cost anything to have them test out the unit if you feel the part is "broken".
Happy Holidays!
Please rate me "4 thumbs" if that was helpful.
Dec 20, 2010 | Maytag 30" Built-In Gas Cooktop - White
I have a GE JGP963 gas cooktop. When you turn the knob the igniters come on all the burners. The spark is good. This works on all knobs. But what happens is that it will not light. It appears there is no...
Hello, Is this a new unit? Is it still under warranty? Has it been recently worked on or converted to another type gas? I'd call the manufacturer (or the company that installed it) and have them send out a qualified technician to fix it. Are the burner flames a nice even blue color? Can you adjust the flames from high to simmer without them going out. If it was converted to another gas type, it's possible the wrong size orifices were put in or possibly that it needs to be converted because it is a natural gas unit that should be changed to propane, or vice-versa. Also be sure the appliance regulator was switched over to the correct type of gas. These are just a few ideas that come to mind. Let me know if any of these apply. Douglas
Sep 12, 2010 | GE 36 in. Profile JGP963 Stainless Steel...
Converted a ge gas to lp. the oven and broiler has too much flame
You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
Dec 21, 2008 | GE 30 in. JGP336 Gas Cooktop
Converting Dacor ERD30S06CH/LP/H to Natural Gas
I know they won't convert gas water heaters but I didn't know they were afraid of stoves. See if your gas company will help. Sometimes they can drill out the orfices. Some of the older repair people still remember how to do this. The orfice for natural gas is larger as the pressure is a lot less. The gas pressure regulator will also need to be replaced. This can be done with a generic part.
Jul 12, 2008 | Dacor Preference SGM365SS Gas Cooktop
Convert to LP?
If it is possible, then the orifice has to be changed. The regulator may need to be changed as well. I am a certified LP technician for recreational vehicles, but I don't know enough about this particular appliance to say for sure if it can be converted. The best thing is to contact Miele directly, but this sort of conversion always requires a different orifice. Note that propane, butane, and natural gas are all forms of LP (Liquified petroleum), so conversion between the 3 is usually possible
Oct 15, 2007 | Miele 35 in. KM326G Gas Cooktop
Thermador PC366BS Stainless Steel Gas Cooktop Logo
54 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
tom wright
tom wright
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
