Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Error code LE
I have the LG dishmasher model LDS5811WW but the manual and the LG web site both don't show what the error code LE means. Any ideas.
thanks so much,
Matt
    President:
  • 373 Answers
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Posted on Jan 19, 2009
LE means locked in motor ..which means replace the motor ....$80 just for motor !
Posted on Jun 13, 2009
  • 5 Answers
Check for dirty filters
Posted on Feb 02, 2009
Thermostat? LG Dishwasher Model: LDS5811WW
Hello Anonymous...
You hit on the reason ($$$$) I come here to contribute... Times are hard, money is scares... and my darling inhabitants are hurting...
Sometimes I can help not throw away a nearly perfect
(and faithful) appliance ... The ULTIMATE in recycling...
((Good for all of us... "inhabitants" (EARTH will be fine)).
((If you have ever seen our home from space...
It's a really pretty place. I'm not so worried for the place...
But there's a CERTAIN magic with these inhabitants...
If we pull together... It will be quite REWARDING)).
So...Thank you for ASKING.
I have a FREE manuals site where I start to read your
owner's manual... Better still... The Manufacturer also
prints "SERVICE MANUALS"...
several are shown... (don't go there yet)
ManualsLib Makes it easy to find manuals online
So being a MORE is BETTER GUY... I chose the one
that occupies the most memory....
and ran through the index 'til we got to trouble codes...
We are starting where your (pretty clever) sweetums found his
CODE clues... and we are going to look backwards..
To find "Thermostat"... (Found "thermistor").
Even if I am WRONG... You will now remember the secret handshake...& always know of the "MAGIC" of errors codes..
(which begin on your FREE page 36...
Although there is another "thermistor" error...
It is an over heat condition.. but it all for the entire PCB (printed control board) to be replaced
LG Dishwasher Main Control Board 6871DD1006Q
Code looks like an EE
with the top bar missing from the first "E"
(making it an inverted "F" (an important difference)...
We are going with ""HE""
HE"(symptom: water is not being heated)
Code yields...
>> HEATER ERROR... (check/replace "thermistor")
LDS5811WW (et al): >> (click here))...
LG DF6810WW Service Manual Page 36
This enables us to search on-line parts houses,
(everybody sells pretty much the same parts... $$, Services & guaranteed fits are different ... (My personal experience SEARS folks a rude, pushy, abusive but make up for all that by their higher than average prices... (I used to be a KENMORE fan))...
SEARS says.. the code is "tE"...
and further states the control board must be replaced
Now I use appliancepartspros, partselect, repairclinic (etc.)...
Sites (with VIDEOS) that respond to an internet search on
"LDS5811WW + thermister"
No "THERMISTER" parts found
Search Over 2 1 Million Appliance Parts
Sadly... Henry (SEARS) says the "thermister" is an integrated part of the HEATER... further adding "the part may be returned if it does not fix your trouble $54.03...ish
(SEARS = guaranteed fit).
Dishwasher Heating Element Part Number 5301DD1001A Sears PartsDirect
http://www.searspartsdirect.com/part-number/5301DD1001A/0022/722.html?modelNumber=LDS5811WW&categoryName=Dishwasher&brandName=LG
I am going to direct your reading to SEARs...
How to Replace Dishwasher Electronic Control Board Repair Guide Help Sears... Pictorial job description:
But do compare prices... and Happy hunting
Carnac the Magnificent
Jul 25, 2017 | LG 24 in. LD-12BW5 Free-standing...
LG DISHWASHER LDS5811WW HAS ERROR CODE LE.WHAT PART DO I NEED?
check for broken wires... if still cant find the problem take motor off and spin the shaft. if there is resistance then you need a new motor
Aug 08, 2010 | LG 24 in. LD-12BW5 Free-standing...
I have an LE error code
yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Jan 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher
The LE code indicates motor failure (or intermittent problem with motor). Based on what Ive read their support sucks, so sory to be bearer of bad news...
Nov 01, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Hi I have a LG dishwasher model no:LD-12AW2 which is comming up on the display LE any idea what that means Thanks Andrew
Hi
Searched on google and found error code LE was a blocked filter cleaned tested ok
Sep 09, 2008 | LG Dishwashers
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
955 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
