Question about Dell Dimension 4600 PC Desktop
PC will not boot from CD drive
PC is a Dell Dimension 4100.
Attempting to do a fresh install of Windows XP Pro
Went into BIOS and reset boot order so CD drive is first. Both CD and DVD drives are operating OK. Tried to boot from both XP Pro and Windows ME CDs. Tried both CDs in both drives.
Neither one works.
Any suggestions greatly appreciated.
    Sergeant:
    Champion:
  • 318 Answers
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Posted on Jan 19, 2009
SOURCE:
I'm trying to reinstall Windowsxp on my Dell dimension 8200. After putting the CD in and it comes up on the screen I click on install Windows XP and then a window pops up that says set up can not continue...
if your using the restore or re-installation CD that came with your DELL computer just boot off the CD.
it will reformat the computer and your data will be lost if you do a fresh install off the CD.
Do not boot into windows and use the CD from there.
make sure you set the bios to boot off the CD follow the instructions on screen to reinstall windows.
Apr 03, 2011 | Dell DIMENSION 3000 CELERON 2.4GHZ...
I am trying to re-install windows xp on a DELL dimension 8300 but it does'nt boot it can go to the BIOS and everything but it say Boot.mgr is missing
You should use the bootable Windows XP CD to start the installation.
To do that, you must first enter the BIOS in the Boot Options select the DVD drive as first (so that it will boot from CD/DVD first, instead of the hard disk). Save and Exit, insert the bootable Windows XP CD in the drive and when prompted to do so, "press any key to boot from CD-Rom".
Hope the above helps.
Mar 13, 2011 | Dell Dimension 8300 PC Desktop
Dimension 5100 and windows xp pro SP3 clean install
I was able to dig this up.
Reference: http://4sysops.com/archives/tip-how-to-install-and-uninstall-a-program-in-safe-mode/
Run Windows in safe mode.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\
Create a registry key REG_SZ key and call it MSIService and value data and call it Service, which is the windows installer. This will give you permission to uninstall windows service Pack 3 from add/remove programs while in safe mode.
May 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Unable to boot the windows xp cd
check your boot settings in the comp bios/cmos set-up, you should the boot order of the devices in your system, make cd/dvd romyour 1st boot device then make the hard drive your 2nd boot device then so on, save the changes you had made and reboot insert your windows installation disc then from there it will boot to the xp cd
Dec 07, 2009 | Dell Dimension 4600C PC Desktop
disable the harddrive in the bios and set the cd to 1 boot.Check sometimes there are 2 cd drive .Cd-rom and the number or model of the dvd drive...
Jan 19, 2009 | Dell Dimension 4600 PC Desktop
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Cant get XP pro on my new drive.
Try letting the Xp OS format the new HD. I am guessing you know already that the old HD has to be disconnected.
Nov 24, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
196 people viewed this question
Ekse
Clive
Clive
