Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Replace recoil starter spring on poulan pro 220
SOURCE: spring repacement
can you tell me if i put the recoll spring back on the saw first to rewind it or do i rewind it then put it back on the saw
Posted on Mar 16, 2009
bobbyburns
SOURCE: Reattaching the recoil spring to the rope pulley
i have the same probelm
Posted on Jul 08, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan Wild Thing 18 Inch replace starter spring?
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Posted on Sep 05, 2009
dontbother10
  • 2220 Answers
SOURCE: broken recoil spring
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
jrox55
  • 66 Answers
SOURCE: poulan pro 220 chainsaw owner's manual for tune-up
you could try cleaning the carb and filter. make sure your fuel lines are clean too
Posted on Feb 27, 2010
Recoil spring problem
I have the same chainsaw and have never had a problem with it.
If you have changed the starter rope or recoil spring in the past, it is important that you hold the new spring with needle nose pliers and install it correctly. Once the spring is in make sure wind the rope correctly-clockwise. If not the new spring will be damaged.
Sep 14, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Rewind pull cord poulan pro snowblower pulled cord first time and will not rewind back
If you are a fix it kind of guy you can remove the starter assembly and check the recoil spring.
Dec 19, 2013 | Poulan Garden
To much slack in pull cord on poulan pro push lawn mower
u need to remove the recoil assbly and restring.remove recoil and cut not out of string.remove line.rotat the coil assbley counter clockwish till spring presser is tight.hold it in place and reinstall cord threw eye whole tie new not and let off recoil slow.slack should go away.
Aug 19, 2013 | Poulan Pro PR550N22SH 22Inch Briggs ...
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Cant remember how to put the spring back on the pull cord recoil
This reply is based on the following assumptions:
A Poulan PP2375LE (wildthing) Type 2
The starter recoil spring is unwound.
All components aer servicable
Poulan 2375LE Type 2 IPL
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Starter components and reassembly order are illustrated on the "Handle, Chassis & Bar Assembly" detail.
If the spring needs rewound this is how I do it, there are other methods.
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool.
This illustrates proper pretension and rope installation:
Smalleng.com (about 3.5 minutes long and worth watching the entire video)
http://www.youtube.com/watch?v=eRyy3MlsjVo
If yours is not a Type 2 you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I hope this was helpful
Lou
Jan 29, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to install a new spring for the pull start in my poulan 220 pro chainsaw
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Nov 01, 2009 | Poulan Garden
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain saw starter rope won't recoil
recoil spring is broke. homedepot has a new one
May 23, 2009 | Garden
Recoil spring broken
you need to supply the brand and model of the blower so i can look it up
Feb 13, 2009 | Poulan 12a Elec Blower/Vacuum
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
182 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
