Question about Cameras
I have a Nikon coolpix L120 and when I try to take a picture it just shuts off. The battery is full, I have tried taking the batteries out and putting them back in but it didnt work
    Sergeant:
  • 475 Answers
Look up in the manual for the problem or call the manufactor and ask them if they have any call back on that make and model.
Posted on Jan 02, 2013
4 Suggested Answers
  • 11967 Answers
SOURCE: My daughter has a Nikon CoolPix S610 that's not
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 24, 2009
  • 11967 Answers
SOURCE: I can't turn on my Nikon Coolpix L1 digital camera
Posted on Dec 09, 2009
SOURCE: Nikon Coolpix L18 display shows
what??im not gettin a new camera, i just got this one less than a month ago. why does it do that?
Posted on Jan 04, 2010
Nikon coolpix L 120 battery exhausted
Sometimes the battery can show up as full with a VOLTAGE but the CURRENT(Read Milli-AMPS) can be low in the cell.
Normally when the load is applied it can shut down as there is no juice within to help with the requirement.
It is best to replace or try a swap with battery to confirm this case without tampering any section.
Dec 11, 2012 | Cameras
I have a Nikon L120 and it will say "Batteries Exhausted" and turn off. I haven't even used it in a week, turn it on, battery is full bar, go to take a pic and "Batteries Exhausted". It can't
Please swap and confirm if this is related to an early battery failure for which you can get a free replacement.. Also if within warranty do not tamper to cancel your warranty.
Nikon L120 shutter release button has to be depressed very hard to work
There is a known design issue with the shutter release switch on the L120. They start to fail after about 1500 shots have been taken. The cause apparently is oxide build-up between the contacts, even though the switch is a sealed unit.
The \'half cock\' works fine, but the shutter release requires considerable pressure to take the shot. It gradually gets worse until it eventually stops working altogether.
There is presently no known solution since the switch is a sealed unit, and is soldered to the internal circuits of the camera. A spare switch is not available on its own- so the entire internal electronics need to be changed.
The replacement part will also fail after the same number of shots have been taken (if you are unlucky), since the same component is still in use.
Solution is to get a new camera. Sad, but true since it is not cost effective to repair.
Nov 30, 2012 | Nikon Coolpix L120 Digital Camera 14.1mp...
Repair spring to open battery case coolpix L120
I wish i had an answer to this, i have the same issue with mine. The battery always shoot out. HELP!! LivePrayTravel@gmail.com
Nov 11, 2012 | Nikon Coolpix L120 Digital Camera 14.1mp...
Shuts off after pic
have you changed your batterys recentley as digital camras work better with rechargable batterys
Jun 18, 2008 | Nikon Coolpix 5600 Digital Camera
Nikon L12 Battery Fault
I don't know if I have the very same problem with my old nikon Coolpix E44600. I may go through the pictures I have already taken but when I try to take a new one, just as I shoot I get the message the "battery exausted" message and the camera shut down.
Jan 27, 2008 | Nikon COOLPIX L12 Digital Camera
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Cameras Logo
1,509 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
