Question about Emerson LD195EM8 19 in. LCD TV
My Emerson LC190EM1 says "format not supported" when I plug in my Sony DVP-SR760H via HDMI. I have tried both of the HDMI inputs on the TV.
I don't know if it matters, but the TV is three years old and both the DVD player and HDMI cord are brand new.
informatica
  • 1114 Answers
SOURCE: Connections on back of TV
You can download the manual from the link below: http://www.emersonaudiovideo.com/pdf/om/EWL3706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 16, 2007
SOURCE: LC32OEM9 says Not Supported Format on HDMI Input.
my playstation3 was hooked up on mine with hdmi, i only recived the message once. i turned the tv off then unplugged the hdmi cable and reconncted it, turned the tv back on and it has been fine ever since.
Posted on May 19, 2009
SOURCE: Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
Posted on Dec 25, 2009
SOURCE: Format not supported when i try to use my emerson
That usually means the "Resolution" is set too high. Try to start in SAFE MODE, press F8 at bootup, and choose, Standard VGA Mode, or boot to the safe mode desktop, then set resolution for say 800x600 32bit. Then reboot. Hopefully you should now be OK.
Posted on Feb 14, 2010
AJIN G
  • 6694 Answers
SOURCE: ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Posted on Dec 14, 2010
The volume control on the remote on our new Sony DVD player DVP SR760H isnt working. We have a goodmans tv model LD3266D. The Sony reference quide doesn't give a compatible code.
That is an off brand of tv. The remote may not support it. You can try following the manual and doing a code search to try and find one that works.
Jan 26, 2017 | Sony Televison & Video
My tv displays "format not supported"
Too many variables with what you are describing here. How old is the TV and how old is the DVD player. Did you verify that the components were all plugged in to their corresponding colors....blue to blue, red to red, green to green. Is the RGB cable verified good. Another common mistake is to plug the video jacks into ex. VID 1 while the Audio is on VID 2. Make sure they are on the same numbered input and that the TV is on the input your jacks are in. The HDMI may not work because there are three different HDMI types and not all play well with each other. The problem can be fixed with an HDMI converter but gets into more cost. Eliminate above mentioned and repost. I would be glad to troubleshoot you through this.
Mar 12, 2014 | Sony DVP-SR500H DVD Player
No sound from DVP-SR760H
https://www.sony.co.uk/electronics/support/home-video-dvd-players.../dvp-sr760hp
This is the manual whereby you can review the many functions of the player.
HDMI being a Complete communication system connects all of the vital components at one time, using one cable format. Thus unless you have a bad cable, the only other issue could be the Player or TV itself. Turn the cable around or try another cable to start with.
Jan 14, 2018 | Televison & Video
How do i get my xbox 360 to work with my tv which is a emerson lc501em3
That TV has an HDMI port so I recommend plugging it in using an HDMI cable. Once you've plugged it in via HDMI, turn on the TV and change the TV's input to the HDMI port. Should just be a matter of finding a button on the TV or the remote labeled "input" and hitting it until it's on the right port.
Feb 10, 2013 | Video Game Consoles & Games
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
EMERSON #LC190EM1 MANUAL
Download the manual from the link below.Type LC190EM1 for the list of available downloads.Click on selection to download.
http://www.emersonaudiovideo.com/support/download.php
Hope this helps.Thanks!
Ken.
Jan 21, 2012 | Emerson Televison & Video
My ps3 is hooked up though HDMI to my emerson lc195emx. but the tv says its an unsupported format. why? is it because the tv only has 720p out put??
Try turning off the power to your console using the power switch in the back (first shut it down properly). Unplug the AV cables (if applicable) and the plug in the HDMI cable. Turn on the system and switch your input on your Television to HDMI. (Keep in mind that there may be a few inputs; HDMI1, HDMI2, etc.) The HDMI connection takes a few seconds so be patient. If that doesn't work, re post or ask to chat.
Feb 05, 2011 | Sony Playstation 3 (PS3) Console
Ps3 hdmi is saying format not supported on my 32"
hi
or try this
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Sony DVP-NS77H No outout
I had the same problem unitl I read the manual a little more carefully.
I found that ALL connections through my AV receiver had to be identical. I was using component connections with analog connections.
Since I switched to all HDMI connections (cable box to AV receiver, DVD to AV receiver and AV receiver to TV) all is fine.
Hope this helps.
Mar 16, 2008 | Televison & Video
Emerson LD195EM8 19 in. LCD TV Logo
104 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
