Question about Refrigerators
Inglis fridge will not get cold but freezer will
  • Anonymous Mar 17, 2014
    Not getting cold after defrost ing it
    Problem Solver:
  • 10 Answers
Ok The problem is that the fan is not running. Do the following first remove the shelves from the freezer and take the screws that holds the panel; there you will find the fan, put some w-40 on the fan and help it spin until it spins on its own. if the fan does not start you must replace the fan. 90% of circulation and cooling problems are caused by this fan.
Posted on Jan 19, 2009
We bought used fridge Inglis/Niagara Model ICT85000 Mfg06/93 when we close fridge door freezer door opens. When we close freeze door fridge door opens. This is a top freezer. Is there a repair
Inglis are a budget make. The cold for the fridge comes from a vent from the freezer. Don't let the door slam. You must close them gently.
Dec 30, 2016 | Refrigerators
Got water dripping into fridge from "vent" from
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Freezer at top of my inglis fridge has many times warmed up for no apparent reason.It is only 1and1/2 years old.Now has stopped working altogether.The fridge is warming up too.It has only a single...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Refrigerators
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Buyers Beware!
go to sears
Aug 14, 2009 | Refrigerators
The coils under the freezer keep getting built up with solid ice so the fridge will not stay cold? Defrosted everything about a month ago when it happened the first time????
Hi, You will need to unplug the defrost drain hole located inside the freezer section under the evaporator coil. Remove the rear panel in the freezer and you can get to the drain. Please let me know if this helps you or if I can assist you further.
Vic
Jul 15, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
My Inglis Refrigerator doesn't make ice anymore,
Had the same problem. Chances are that the water has frozen in the supply tube, not allowing water into the maker. you will need to unplug and thaw out your fridge entirely to thaw it out. I used a hair dryer pointed at the filler tube to defrost it.
Jun 23, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Mar 09, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
My freezer works perfect but everything in the refrigerator doesn't get cold enough. My milk sours. My fridge is an inglis and supposedly brand new
Warm fridge cold freezer problem fixed
In the freezer section there was a one screw removable panel which housed a four bladed rotary fan. One blade had broken off adn was jamming the fan from rotating. Once the broken part was removed the fan was free to rotate, but out of balance, but it did get the fridge going again. It took about one minute to replace the fan once a spare was aquired. Now I understand how it works, if one side of your fridge freezer is not working it can only be the air movement or lack of it Robert
Robert
Dec 30, 2008 | Refrigerators
Refrigerators Logo
929 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
