Question about Speed Queen SWT921 Top Load Washer
Coin drop not registering coins to start
Washer works fine goes through cylcles but will not start when coins are added
3 Suggested Answers
SOURCE: Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Posted on Jul 12, 2012
pgehrmann
SOURCE: Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
Posted on Dec 04, 2012
Coins
It might well be a coin! Coins and other items that fall from clothes pockets into the drum stay in the drum. They are too large to pass through the small drainage holes in the drum. But my granddaughter found a way! She opened the washing powder dispenser at the top of the machine and dropped three coins (that we know about) into the drawer and closed it. The water fill cycle then somehow swept the coins down into the drum. To get them out I had to dismantle the machine and remove the pump outlet assembly and poke a stiff wire into the drum and drag the coins out. The machine is a completely different make to your but I would assume a similar method would work. good luck
Dec 31, 2013 | General Electric GTWS8655DMC GER 5.0 DOE...
We have a Maytag MAH21PDDWW Washer when you put coins in it will not show you put a coin in but is you remove the maintenance cover you will see a * each time he put a coin in, is there a reset for this...
Hi and welcome to FixYa, I am Kelly. It is possible that the coin drop acceptor is dirty. See page 22 of this manual:
http://www.fowlercompanies.com/SM/Maytag%20Service%20Manuals/MAH21SERVICE.pdf.
On page 23 there is also a guide rail adjustment.
The processor will pretty much go into a tamper proof mode that will not accept any coins you input if there is a problem with the sensor bar or guide rail. I suspect you have a guide rail that needs adjustment. The manual explains the adjustment procedure on page 23.
Thanks for choosing FixYa,
Kelly
Sep 01, 2011 | Maytag Neptune Washer
Can i add a coin machine to a Kenmore washer, model# 28432700?
any machine can have a coin collector added to it, they come in different styles and varieties, if you just google it , you can see a bunch, heres one
http://www.speeder-ltd.co.uk/laundry-control-coin-boxes-machines.aspx
Aug 03, 2011 | Kenmore Washing Machines
Will not drain and stops but does not give an error code.
Check any pump filter and outlet hose for blockages, if all is ok check pump.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 06, 2011 | Maytag Neptune Washer
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Nov 19, 2008 | Zanussi ZWF1430W Front Load Washer
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Oct 24, 2008 | Maytag Washing Machines
Kenmore 20172 Washer does nothing when coins drop
Sounds like the lever for the coin box needs an adjusment. It may not be far enough back to engage the lever to start it.
May 07, 2008 | Kenmore 20172 Top Load Washer
Speed Queen SWT921 Top Load Washer Logo
101 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
