The program can't start becuase snlBase150.bpl is missing from your compyter
4 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: Need rtl100.bpl for Acer
You probably read web pages written in a language that displays Right To Left
(hence rtl100) There are several reasons why that file might corrupt, an
add-on of some kind being the main suspect. Go to start/run, and type:
iexplore -extoff
to see it that stops the error.
If not, try refreshing all system files with :
sfc /scannow
If you use the sfc command you may need your original windows install disk.
If you have Realtek sound or network device check this out >>>>>
http://support.microsoft.com/default.aspx/kb/935448/en-us
Regards
Posted on Aug 03, 2009
  • 811 Answers
SOURCE: The program can't start because
RTL120.bpl is a CodeGear runtime library, an application is trying to launch at start up and can't find this. Reinstall the application you suspect is causing the problem. It is generally a anti-virus or a advanced system care program you really do not need any of these programs I use just a suggestion to make my machines run more efficiently Microsoft Security Essentials it does it all and runs in the background and less intrusive dump the software that is cleaning up your computer. Like Advanced System Care an easy way to uninstall software is also to download a program called ccleaner you can get this free at ccleaner.com then you can easily see software installed on your system and can delete it what you do not need. Just a suggestion. Thanks for using FixYa! John
Posted on Feb 14, 2011
ZorWiz
  • 120 Answers
Google 'download rtl120.bpl'.
Download the file from the list and put it in C:\WIndows\System32
You may be asked for other libraries too. Just do the same thing to get them.
Posted on Jun 19, 2011
How do i download snlbase150.bpl
You don't want to its a virus.
You need to get hold of some free anti-virus software to get rid of it. Try
SUPERAntiSpyware Remove Malware Remove Spyware AntiMalware AntiSpyware...
Oct 04, 2014 | Computers & Internet
Tune up utilities problem of rti100.bpl is missing, how to fix?
Try doing a system restore to revert the changes that you made in the computer.
Click on the Pearl Button or Start > Programs > Accessories > System Tools > System Restore
Select a date when the program was still working great.
Let it complete the restoration and let it restart by itself. I hope this helps!
David
Apr 19, 2013 | Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
The program can't start because rtl120.bpl is missing from your computer. Try reinstalling the program to fix this problem.
Jun 19, 2011 | Computers & Internet
Ultimate windows 7. ''the program cannot start because your missing rtl100bpl''
You are probably using a program built with Delphi, and somehow it's missing the Borland Programming Language (BPL) Run-Time Library 1.00. Hence, "rtl100.bpl".
If this is the case, download any Delphi runtime package - for example this one:
http://www.lexically.net/downloads/version5/base1a.zip
and find inside the RTL100.BPL file. Unpack it in the C:\WINDOWS\SYSTEM32 folder, and that should be it.
Jan 06, 2010 | HP Pavilion M9040N Elite Desktop PC
What is rtl120.bpl. A box appeared whenever I start my PC, asking me to re-install rtl120.bpl. I am confused.? re-install rtl120.bpl. Lost Adnanced System care at the same time ?
The error could be connected to the advanced system care. Have you uninstalled any protective software lately?
It would seem that as the computer is starting it is trying to load a program that is either corrupt or missing, generally a program like reg cleaner or other utility program.
If its a case you have removed a program, try installing it and see if that works.
Get another copy of the advanced sys care program and reinstall that.
If this doesn't work, get back to me.
Dec 07, 2009 | Toshiba Satellite A60 Notebook
Open Questions:
Norton Tech Support Number 1*888*866*2O82 Phone Number for Norton Technical Support Norton Tech Support Number 1*888*866*2O82 Phone Number for Norton Tech Support, Norton Tech Support Number Norton tech support phone number 1*888*866*2O82 Norton Tech Support Phone Number Norton Tech Support Number 1*888*866*2O82 Norton Tech Support Phone Number Norton Antivirus contact number, Norton Antivirus telephone number.Norton not working, Norton troubleshooting phone number, Norton troubleshooting support number Norton tech support, Norton tech support number, Norton tech support number usa, Norton customer service chat, Norton internet security customer service phone number, Norton numbe number customer service Norton antivirus phone Norton 360 support number call Norton antivirus Norton 360 contact phone number Norton Antivirus phone number, Norton Antivirus support phone number, Norton Antivirus techncal support phone number.Norton help phone number, Norton help number. Norton help desk number, Norton help desk phone number, Norton tech care number, Norton tech care phone number, Norton tech support telephone number, Norton technical support telephone number, Norton phone number phone number, Norton not working, Norton troubleshooting phone number, Norton troubleshooting support number Norton tech support, Norton tech support number, Norton tech support number usa, Norton customer service chat, Norton internet security customer service phone number, Norton number, phone number Norton Antivirus tech support Norton phone number Norton support phone number Norton tech support number Norton technical support number Norton customer support number Norton customer SUPPORT number Norton customer care number Norton toll free number Norton helpdesk number Norton contact number Norton telephone number Norton support phone number Norton tech support phone number Norton technical support phone number.
May 21, 2018 | Norton Computers & Internet
norton help desk USA&Canada -1*888*866*2O82 Norton support phone number Norton antivirus tech support phone numberNorton Phone Number norton help desk USA&Canada - 1*888*866*2O82 Norton support phone number Norton antivirus tech support phone numberNorton Phone Number Norton contact phone number contact number for Norton antivirus contact number for Norton Norton antivirus technical support Norton antivirus customer support number phone number for Norton antivirus support Norton help chat call Norton Norton customer support phone number Norton antivirus canada Norton antivirus contact phone number Norton online support Norton antivirus 1800 number contact Norton internet security telephone number for Norton antivirus telephone number for Norton antivirus customer service Norton internet security tech support phone number Norton symantec support contact Norton antivirus customer service phone number Norton internet security contact phone number contact Norton 360 Norton tech support number Norton help phone number phone for Norton customer support Norton internet security customer service Norton antivirus help phone number Norton security help phone number Norton antivirus customer care number phone number for Norton 360 telephone number for Norton security Norton antivirus telephone number customer service Norton internet security contact Norton virus protection contact number Norton internet security help Norton virus phone number Norton customer support telephone number Norton antivirus phone support Norton by symantec phone number telephone number for Norton internet security Norton support contact number Norton internet security customer service number Norton phone number customer service call Norton antivirus customer service Norton antivirus help desk phone number Norton antivirus phone number support contact number for Norton internet security phone number for Norton internet security Norton antivirus help desk number Norton antivirus customer support Norton phone number support Norton tech support Norton contact Norton contact support Norton 1800 support number phone number Norton antivirus customer service number for Norton antivirus Norton telephone support call Norton security Norton antivirus customer care phone number Norton antivirus online Norton online help Norton security helpline Norton install Norton telephone number customer service Norton antivirus phone Norton tech support chat call Norton antivirus Norton internet security technical support phone number Norton antivirus customer service telephone number Norton antivirus support telephone number Norton com phone number Norton antivirus help number
May 21, 2018 | Symantec Computers & Internet
Computers & Internet Logo
1,001 people viewed this question
David Payne
David Payne
