Question about Philips 60PP9352 60" Rear Projection Television
Power turns off immediately.
I was wondering if you could explain where the transistors are located? I am hurting without this tv right now. It used to only click once then try again and worked. Then moved to 2-3 trys. Now none. just one click and turns off. thanks alot.
  • 5 more comments
  • Robert Dressler Jan 19, 2009
    Does that sound the same? the tv is cold, just clicks on and then off. what would you suggest? Thank you very much for fast response.
    **** I really cannot afford to hire someone. Is there a way to take pics and send them to you? I really do appreciate what you are doing for me. thanks. I have the service manual and still have no idea where the HV gen is. What do transistors look like? and also how hard would it be to fix it? I am somewhat ok with soldering. Thanks
    you are great. thanks. I will take the board off and see what the soldering looks like. Do you think the soldering goes bad or the part most of the time? If so, how would I test it out without buying a new one. You were very helpful. thanks.
    While looking at the HV that is not noticeably bad but I noticed right next to it listed as Coil, 5u1. . 2422 549 45206 in the service manual. it looks crinkled up at the top, I dont know if it normally looks like it but might be something. here is the pic of the coil and hv. thanks.
    ok, I will take the circuit board off and look for some bad solder. Wouldnt the hot transistor be only hot when on a long time? I may be wrong. but.... I really dont want it to be the board. How much is a board? Do you have any idea where to order or buy one or even what exactly it is called? Thank you very much. Robert
  • Robert Dressler Jan 30, 2009
    I talked with a guy at work that says he thinks that it could be the switch that is shorting then finally gave out. Does that sound like something it could be? I was looking at the schematic and cannot seem to find the switch on the board. Any ideas? Thanks alot.
    yes the light does turn on. ****. I have put off taking off the board. but I guess I have no choice. Im calling a repairman.
  • Philips Master
  • 8,617 Answers
They are located on the center board mounted to aluminum heatsinks
Posted on Jan 19, 2009
  • 2 more comments
  • Sonny Berry
    Sonny Berry Jan 19, 2009
    Its usually related to a bad solder joints around the HV generator or Hot Transistors on that model, Bad solder joints will appear dull gray instead of bright silver
  • Sonny Berry
    this what the hv generator looks like there will be three large red wires coming out of the top of it
  • Sonny Berry
    Yes, thats normal for the coils. Thats shrink wrapped to protect the copper wire tat is raped around the coil. Often it can be solder , however if you dont ntice any that appears dull gray it will most likely be a HOT Transistor and HV generator or a Bad LSB board.
  • Sonny Berry
    Sonny Berry Jan 30, 2009
    It could be the switch possibly. the switch is actually on the front keybaord panel. although if the power led lights up when the power button is pressed that indicates the switch is functioning
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
Tip
If Your screen shows a: white vertical line on a black screen or, a white...
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, carefully using your finger find the too hot transistor or, chip; or, use component coolant; spray the too hot component with a component cooler repower the TV, until the screen comes back to normal. To fix: apply white sylicone coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Garden
Turns on immediately turns off
check for shorted component parts at power supply board like bridge type diode and FET transistor. if those are good, disconnect the connectors that supply going to inverter board and then turn on the tv unit if the light indicator at front panel stay and 24v supply doesn't drop which mean the inverter board was the problem of suddenly turn off.
Sep 01, 2012 | Samsung LN19B650 18.5 in. HDTV LCD TV
Tv will not turn on. I have unplugged it and tried another outlet but still will not turn on. There is power going through the Tv. Any thought on what it could be
check your b+ first. if your tv has no 125 volts your tv will not turn on check your horizontal transistor located in the side of the flyback transformer unsolder the collector then try to power on your tv check your high voltage at the collector without the collector of the horizontal transistor.
Dec 22, 2010 | Akai CF2791 27" TV
My Panosonic TV Model# PT-47WX42F will not turn on. It clicks like it wants to turn on but does not. The power light is flashing 5 times
5 blinks is error code for short on 140 volt line inside the set; it usually means the Horz output transistor is shorted. If you have a ohm meter (used for checking fuses etc) there is a simple test to see if this is the problem.
Also associated with this is a bad capacitor near it (Location for the Transistor is C509 and the transistor should be location Q551)
Location numbers are printed on top of board near part; both parts are on (as seen from back) far right board near the large black part with big red wire coming out of the top.
Transistor is just to the left of it and cap forward about 3 inches.
If this information told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 30, 2010 | Panasonic PT-47WX53 47" Rear Projection...
No power, stanby only
standby sont tv?...you need to open the back cover of your tv..check whether you fuse are blown/open...if yes,do not replace right away the fuse there might be a problem on the main supplys...using yuor multitester check your horizontal output transistor..it is located near the plyback transformer..if you do not now the correct testing of the transistor replace it with a new transistor...same with the regulator replace it with a new one...then replace the fuse ..your tv is now working again..
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV making chirping sound
If one of the secondary supplies is shorted, the power supply will "chirp" when plugged in. This is the power supply's way of protecting itself and this usually happens when the horizontal output transistor is shorted. If this set was in my shop and needed a new output transistor, a fair price would be right around $100.
Jun 28, 2007 | Toshiba 32DF46 32" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Philips 60PP9352 60" Rear Projection Television Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
