Question about Amana ABB1927DE Bottom Freezer Refrigerator
How do I get to the coils on my Amana ARB1914 to clean them?
How do I get to the coils on my Amana ARB1914 bottom freezer refrigerator? They are next to the floor. I can't really get to them from the front or the back. Seems like I can only clean a little bit around the edges.
    President:
  • Amana Master
  • 2,651 Answers
Youll need to use a refrigeration coil brush, similliar to this http://www.repairclinic.com/SSPartDetail.aspx?PartID=12859&Acc=1&PPStack=1
Posted on Jan 19, 2009
Amana BR18V1S is running but fridge temperature is low (slightly cool) Checked everything, cleaned coils (very dirty) Freezer OK.
Check and see if the freezer coils are blocked with ice. If not you may have a refrigerant problem as you stated the coils were dirty. The new refrigerants when hot tend to clog the capillary tube which feeds the refrigerant to the evaporator (freezer coils)
Jun 06, 2011 | Amana Bottom Mount Refrigerator 22 cu ft -...
Amana top fridge and bottom freezer both stopped working overnight, cleaned out all the dust and dirt from below
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 19, 2011 | Amana ARB2217CSR Bottom Freezer...
Problem with the Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Clicking, buzzing, compressor too hot, thawed out freezer, fridge is semi cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 10, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Top fridge will not keep cold,and no air flow is present when compressor is running.The bottom freezer chest stays cold. I cleaned the coils....what should I try next?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 01, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Freezer freezes but frig wont cool amana with freezer on the bottom
I couldn't find a repairman so I pulled the big thing away from the wall, took off the bottom front plate and the bottom rear plate and unplugged the big beast. Then using a refrigerator brush and a vacuum I carefully cleaned all the dustballs from the coils on the bottom. Then plugged it back in and in about 3 hours it was cooling normally again on a "4" setting.
Jul 13, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana model ARB1914 with 1C11B icemaker has deformed ice cubes
Heat guns are typically a bad idea as most people will hold it in one place too long melting,or disfiguring the plastic on the icemaker or worse,the cabinet.
Removing and using hot water is always the best way!
The usual problem for small, or hollow ice cubes is a bad saddle valve. There really isn't a good saddle valve in my opinion as they always clog either from mineral or rusting from the inside out.
What you want to do is find your shutoff valve. Sometimes in the basement, or under a sink if it is close by the refrigerator and look to see how it is hooked up. If it has a valve like the attached pic then it would be best to call in a plumber and have him replace it with a toilet style ball valve which will never restrict water flow and will always work!
The two main types of saddle valves are self pierce (absolute garbage) and drill type. If you look at where the valve straps to the pipe it will either have a round or square gasket. The square gasket ones are the worst and 99.5% of the time are the problem.
Feb 01, 2018 | Amana ABB1927DE Bottom Freezer...
I have an Amana "R" Series Bottom Freezer Refrigerator model Bx20RL purchased in 1995. The freezer is working but the refrigerator section is warm. I've cleaned the coils regularly and just did so again....
It is either a defrost timer or limit switch, That's the little clip on device located on top of one of your freezer coils. This is the most common item to die on many newer refrigerators2_bing.gif. It is also pretty inexpensive, and easy to get from Sears or 1stsource parts. In rare cases your defrost heater may go bad, but I haven't had to replace one in a long while.
Mar 10, 2010 | Amana ABB1927DE Bottom Freezer...
Amana abb2224des with Bottom freezer. Just
the least you remove the better.use vacuum cleaner hose to collect s..t (dust) easier than wet cloth.
Feb 11, 2010 | Amana ABB2224DES Stainless Steel Bottom...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
631 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
