Question about Brother HL4040CN Laser Printer
Hl4040cn will not print test page
Have hl4040cn connected to wifes new windows 8 laptop via usb and it will ot print test page.. suspect paper feed problem...thanks
    Sergeant:
  • Brother Expert
  • 316 Answers
Try doing a machine self test to ensure that it is working properly.
Press OK/return to "Machine Info"
Then down arrow once to "Test Print" and OK/Return.
The machine should produce a self test printout. If the machine does not give a print out, try cleaning the paper pick up rollers at the back of the paper tray cavity. Be careful, the machine is heavy.
If a full test print happens - Your printer is working fine and the problem is at the computer end.
It's possible driver installion is faulty or incomplete and you should try re-installing the printer driver. Is it also possible that your printer paper settings are either incorrect or do not match the paper in the printer. Check and match your paper settings in the printer preferences and the paper tray.
Posted on Nov 08, 2013
  • 253 Answers
SOURCE: WHILE TRYING TO FIGURE OUT WHY MY PRINT QUALITY IS
If it has been happening since you put those cartridges in, I would suspest the cartridge. most of them have the actual Printhead built on the cart.(it's what actually spits out the ink from the cart.) if they become clogged with dried ink, they will give poor performance. you may have gotten a cartridge that got to hot in shipping or something, and was bad in the package.
Have you tried another cartridge, are these refills, if so I say thats your problem the cartridge
Posted on Mar 30, 2009
  • 26 Answers
SOURCE: MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
Posted on Aug 18, 2009
xptareq2000
  • 1447 Answers
SOURCE: Just bought a new brother HL-2170W, installed the
it is problem your operating system or driver installation
Posted on Sep 07, 2009
  • 1121 Answers
SOURCE: I have a Brother HL2170W that will print in USB as
install driver printer software for wireless, but first, diconnect usb and ethernet, and test.
Posted on Jan 09, 2010
  • 2386 Answers
SOURCE: Hello, I have a
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Posted on Nov 25, 2010
Kyocera FS-1020D starts print 1/2 way down page
Internal tests like Report Prints are printed correctly? Make sure the Paper Size Format is setted correctly both on PC and Printer. Try not to use a Generic or Universal Printer Driver. Try installing printer with an Windows Vista driver if the Win7 and 8 drivers won't solve the problem.
Jan 22, 2015 | Kyocera Office Equipment & Supplies
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Errors with my Printer/scaner
Jessica:
This could be one of a few things... First, Windows 8 is a completely different animal from Windows XP! Try reloading your printer driver in Windows 8. If this doesn\'t work, you need to clean the paper pickup rollers at the front of the printer (where the paper first feeds into the machine. I use a Q-tip moistened (not sopping wet) with rubbing alcohol... gently scrub the whole pickup roller and then the feed roller next to it. Check carefully (with a flashlight) for any shards of paper that might be blocking the paper path. There is also a sensor flag (small finger of plastic) sticking up that the paper must hit to let the printer know that the paper is feeding through. If you do not see the sensor flag, it is either jammed or has been broken off when a piece of paper was pulled backward out of the paper feed area. First reload the printer driver, and try to print. If it doesn\'t print, check and clean the rollers and look for the sensor flag.
May 31, 2014 | HP 1050 Plain Paper Inkjet Fax
HP printer installed itself just fine via USB for a laptop with Windows 8 but it still won't print (even after reboot). Just trying to help a fine lady.
Ok.. press Windows and then r..then type services.msc
search for print spooler and then restart it. after that restart your system and try printing a test page..
Sep 30, 2013 | HP OfficeJet Office Equipment & Supplies
Connected Canon MP610 to Apple Time capsule via USB. My Macbook pro prints wirelessly perfectly, as does my sons Vista Laptop, however my daughters vista laptop and my wifes XP laptop print black fine, but...
Hi richardhaley,
Isee that you are having issues with your Canon MP610 printer.
You mentioned that your printer is connected to an Apple Time capsule via USB and that it works fin on your Macbook and on your sons Vista Laptop but prints the colored shifted to the right on your daughter's Vista and wife's XP Laptop and this is connected via USB.
If I may ask have you tried printing wireless using your daughters Vista Laptop and you wife's XP Laptop to see if the colors are still gonna shifted to the right.
Also you mentioned the drive that the driver you are using is from bonjour but still you have the same problem.
Here is a link where you can download drivers specific for the versions of windows your daughter's Vista and your wife's XP would have, you will need to select exactly the OS operating system for the driver that you need also there is a software for each Operating system as well maybe you can download that as well for both system for you to be able to recalibrate the printer from the 2 machines.
I hope that this will help.
Thank you for choosing Fixya,
mvincentc
Jun 06, 2011 | Canon MP610 Photo All-In-One Printer
How can I make a printing test without connect my printer to the pc?
How to Perform the Hardware Test on a Lexmark Z840 and Z845 Color Jetprinter Document ID:HO3002 Properties Lexmark Z845How to perform the hardware test; Hardware test; Lexmark Z840 Color Jetprinter; Microsoft Windows 98; Microsoft Windows Me; Microsoft Windows 2000; Microsoft Windows Server 2003; Microsoft Windows XP Professional x64 Edition; Microsoft Windows XP
Solution Performing the Hardware Test
    1. Turn off the printer.
    2. Press and hold the Paper Feed button.
    3. While continuing to hold down the Paper Feed button, press the Power button ONCE.
    4. When the Power button begins to flash rapidly, release the Paper Feed button. A test page will print.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Lexmark Z845 InkJet Printer
HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
May 06, 2009 | HP LaserJet 1018 Printer
Cannon MP460 will feed paper through printer but not print
Check your printer sharing in the system preferences... make sure it's on.. then when you get the print window, look for your printer under shared printers... try it that way... worked for me on my wifi network here.
Mar 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Printing problems
plz check whether the driver is installed, go to printers on control panel and try for a test page print, if test is printed, then could be ur software is looking that printer.
Aug 18, 2008 | ASUS Eee 4G Notebook
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Brother HL4040CN Laser Printer Logo
124 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
