We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
  • Anonymous Mar 27, 2014
    Monitor heater is hot to the touch... never happened before. Thoughts?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Posted on Jan 19, 2009
    New Friend:
I have a 2400 monitor heater,after being on for awhile it starts beeping-why
Posted on Aug 13, 2014
Kerosene Heater starts up and then shuts down
David, you need a copy of the Troubleshooting Manual here:
http://www.toyotomiusa.com/OwnersManuals/Portable%20Heaters/Name%20begins%20with%20LR%20or%20LS/LR-350%20LR-450%20Troubleshooting%20manual.pdf
It sure sounds like a failure during pre-ignition. Page 5 covers both of your burn times with two different Flow charts.
A yellowish flame can mean a warped flame ring or incorrect air flow.
Dec 29, 2014 | Heating & Cooling
Starts runs for 3minutes then shuts off
pressure should b at 6 to 6.5 clean nozzle check for cracks in air ling and fuel make sure both filters r clean and the flame sensor is clean good luck
Dec 07, 2013 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Repair manual for a Monitor 2400 kerosene heater system
I just bought a use Monitor 2400,it will run and then start to beep,has E 14 on it, What does that mean? Don't have the manual for it.
Feb 02, 2012 | Heating & Cooling
I have an All Pro 150000 btu kerosene / diesel torpedo heater. It runs for a few minutes and then starts sputtering, shooting flames and smoke. What causes this problem?
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Monitor 2400 Kerosene heater service
Check your filter in the fuel line outside if you have one. Also check the strainer in the fuel sump.
Feb 02, 2010 | Heating & Cooling
100000Btu Reddy kerosene heater fires up then shuts down after a few seconds to a few minutes
1. Check the fuel nozzle if it produces an atomized
spray of the kerosene all the time.
2. If it doesn't atomize, pls check the fuel pump, it is
working right.
3. Your igniter is working, since it fires up.
Check item 1 & 2 must be satisfied to get it to working
condition. Hope this help.
Jan 06, 2010 | Heating & Cooling
Kerosene heater cuts off after a few seconds
Photo celll rarely goes out, but time to remove the gum out!---or OVERHAUL TIME!
Dec 18, 2009 | Heating & Cooling
Was running fine, then shut off and smoked like out of fuel.
THERE ARE THREE OR FOUR REASONS FOR THIS. DIRTY FUEL FILTER, FUEL PRESSURE INCORRECT, DIRTY AIR AND LINT FILTER, THE ELECTRIC EYE THAT SEES THE FLAME IS BAD, OR THE CONTROL BOARD IS BAD. THESE ARE MANUFACTURED BY MESA OUT OF BOWLING GREEN, KY AND THEY HAVE A WEBSITE. I GOT MY NEW PARTS AT MY LOCAL RURAL KING STORE.
Jan 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
979 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
