Without knowing anything about the camera to which you refer, it is impossible to offer specific advice. From the minute amount of information you have given us, it would appear that the memory for recording further images is full, as it has a finite capacity. This is probably mentioned in the manual. To clear the memory, back up the images to external storage of some kind, then delete the images on the camera. Alternatively, if you have been saving images to a media card of some description, merely purchase a new one and replace it.
The previous reply is for Opticon with an 'N' not 'Opticom' with an M and a different company, so not very helpful. I haven't found an online copy of the manual so far. 1. Lift up the handset. 2. Press the STO button (for 'Store') 3. Key in the full number you want to store, e.g. 01234 5678910 4. Press STO again 5. Press one of the numbers on the key pad that you want to be the Quickdial number, from 1 to 0. 6. Press the MEM (Memory) button. 7. Replace the handset in its cradle. 8. The Quickdial number will now be stored and you can call it by lifting the handset (or pressing the speakerphone button) and then pressing the MEM button followed by the single number you chose, e.g. MEM then 3.
This happened to me (well, actually to my wife...). This is what I did to fix it, after lots of fruitless reading of the manual: Press the tape button (bttom right) so the display shows ANS RECORD. Press MEMO REC. The display shows MEM FULL. Press MEMO PLAY, then (quite quickly) DELETE. Problem solved!
Hello Ken, If the mem bank of printer is full it will slow down, go into Control panal on PC, hit Printer icon, highlight icon and right mouse click, go to prop click empty drafts and copies, and you will see the junk go in bin.
First off did you format ur memory card? Casio only has 3 brands of memory cards they have tested their cameras with....Sandisc, Toshiba, and Panasonic. The exz600 can take up to a 2 GB card from those manufacturers with no problem.
I would make sure that your mem card is formatted. If it is, try a different card.
If you don't care about the pics that are stored on your internal mem then you can format your camera, put in a new mem card and then format that.
You always have the option of transfering the pics to ur computer first before formatting.
After formatting make sure you reset your camera also.
Format:
in REC mode press menu
go to setup tab
go up to format
press right arrow
make sure format highlighted and press set
Camera will say "busy please wait"
Reset:
In REC mode press menu
go to setup tab
go up to reset
press right arrow
make sure reset is highlighted & press set.
