Question about GM Carts 02 03 04 05 06 07 08 Chevy Trailblazer Antenna Gm88
How to change an oil pump on 6.0 vortec - GM Carts 02 03 04 05 06 07 08 Chevy Trailblazer Antenna Gm88
How many quarts of transmission fluid in a 4.2
11.2 quarts from dry, including torque converter. When just changing the filter, between 5-7 quarts. Dexron 6 is the best, and newest technology from GM.
Oct 02, 2015 | 2004 Chevrolet TrailBlazer
Engine is ticking/knocking 2003gmc envoy inline 6 vortec any known problems,or just normal vortec tick?
<shrugs> yes and no, maybe
put up a youtube video on it
main thing is your check engine light on or any trouble codes?
oil changes and keep en eye on the level; too low and / or dirtly oil may exhibit more noise than normal
Apr 01, 2015 | 2003 GMC Envoy
Suburban oil pressure sending unit
FIRST you need to get an actual oil pressure tester to hook up directly to where the oil pressure bulb is and see what you get there...
Dec 18, 2013 | Cars & Trucks
I have a 1995 K2500 that had the motor changed to a HD 383 Stroker before I bought it / It also has vortec heads. The oil pressure seems really low to me. About 2 to 5 lbs at idle. About 30 to 35 lb
That will burn out the engines bearings, if it knocks at all it is to late. Do verify the reading with a mechanical gauge if you haven't done so already. The rule is this at least 10-15 pounds at idle with hot oil, 10 PSI per 1000 RPM of engine speed. If engine is not knocking then replace the oil pump with a high pressure high volume pump.
Oct 09, 2012 | Cars & Trucks
I am having a problem after warm up and at idle speed the oil pressure drop low enought to trigger the check gauges light. I have been trying to trouble shoot the problem with oil changes etc. but it is...
4.3L Engine To Remove:
  1. Remove or disconnect the following:
    • Engine oil pan
    • The oil pump
    • Inspect the pins (oil pump locator) for damage gm_truck_43_ol-pmp_loctr-pns.gif
      1. Replace the pins if required
  2. Clean and inspect all parts.
To Install:
  1. Inspect for properly installed pins (oil pump locator). Note: Do not reuse the oil pump driveshaft retainer. During assembly, install a new oil pump driveshaft retainer.
  2. Install or connect the following:
    • The oil pump
      1. Position the oil pump onto the pins
    • The oil pump bolt attaching the oil pump to the rear crankshaft bearing cap
      1. Tighten the oil pump bolt, Torque to: 66 lb ft (90 Nm)
    • The oil pan
Jul 13, 2010 | 1994 GMC Sonoma
Whats needed to convert 1996 from 5.0L vortec to 5.7L vortec
hi all the exturnel parts are the same a 350 will go right in .the valve covers,intake oil pan all the same
Jul 20, 2009 | 1996 GMC Sierra
My 03 suburbans oil life stayed at 6% after oil change how do i r
Turn the key on and push the gas pedal all the way down 3 times.
Jul 04, 2009 | 2007 Chevrolet Cobalt Coupe
1999 chevy blazer wont start
THE FUEL PUMP IS BAD.
if your losing fuel pressure after the pump runs the drain back valve in the pump has failed.
and i doubt that you are seeing enough fuel pressure to run a vortec engine.
low fuel pressure equals a non running vortec
Apr 11, 2009 | 1999 Chevrolet Blazer
GM Carts 02 03 04 05 06 07 08 Chevy Trailblazer Antenna Gm88 Logo
103 people viewed this question
Top GM Carts Car Audio & Video Experts
Ryan Lutton
Ryan Lutton
David Rodriguez
David Rodriguez
Level 1 Expert
Are you a GM Carts Car Audio and Video Expert? Answer questions, earn points and help others
