Question about GE Washing Machines
How to fix broken infusor asm on ge top loading washing machine
5 Suggested Answers
  • 71 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Posted on Dec 15, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
  • 109 Answers
SOURCE: I have a GE top load washer model G157. When I
timer is bad
Posted on Aug 23, 2009
How do I replace a broken start switch
Washer Start Button Replacement -GE Top-Load Washing ...
? 2:05
https://www.youtube.com/watch?v=tEVwT4mL9ZU
Sep 27, 2012 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacingthe start button on a GE top-loading washing ...
Cabrio Washer Start Button Broken Quick Fix - YouTube
? 5:54
https://www.youtube.com/watch?v=h1CRcehOCxY
Mar 23, 2015 - Uploaded by FreidasGarden
This video is about Cabrio Washer Start Button Broken QuickFix. I hope it helps you get some wash done
Nov 28, 2015 | Washing Machines
Will not spin the water out of the clothes
call a repairman sounds like a controller problem or transmission not getting final rinse signal
Mar 15, 2015 | GE Profile PTWN6050MWT 27" Top-Load Washer...
GE WBHV5200J3WW shakes during spin cycle with load in the machine
you might need a new Motor Asm Kit part number WH20X10028
the pic below is Motor Asm Kit that you might need okay
Jan 29, 2013 | Washing Machines
The infusor on my GE PTWN8050MWW Washer is detached. It is spinning loosely and floats up when the tub is filled. How do I fix it?
If the screw holding the infusor to the shank is not broken, more than likely the shaft broke. That is what happened to mine. The part is like 339 bucks and you need to tear it apart to install it. Sorry.
Jan 12, 2013 | GE PTWN8050MWW Washer
Remove ge infusor
open the detergent snap lid and there are 2 half round ears turn these counterclockwise and it will lift out
Jun 17, 2012 | General Electric Profile WPRE8150KWT 4.1...
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash. http://www.appliance-repair-it.com/ge-washer-lights-blink-after-replacing-the-control-board.html
Sep 13, 2010 | GE WBSE3120B Top Load Washer
I have a ge profile top load washer and the knob is broken how do I remove it to fix it? The cycle knob just spins I am unable to wash,
I would look at some of the internet appliance parts sites for a replacement part. Uusally a good illustration will give you a clue as to how it is attached. You can also contact GE internet site.
http://genet.geappliances.com/DocSearch/Dispatcher
Worst case senerio is the timer. Post the question to GE.
Jul 10, 2010 | GE Profile WPRE6100G Top Load Washer
Purchased a GE washer WHRE5550kww need to know why it isn't filling to the top 'holes' when set on large/super wash?
Hello....I don't know the answer to your question, but would like to know if you like this machine in general, are you happy you bought it??? Would you buy it again? Thanks
Aug 04, 2009 | General Electric WHRE5550H Top Load Washer
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Have to hit start button several times over first few minutes, due to it shutting off. I think it may be a faulty switch?
I have the exact same problem.. (I suggested I'm going to replace the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303) found one for $45 at partadvantage.com
Nov 15, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
37 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
