Question about Honda Garden
How to buy parts for a honda generac 6.5 hp pressure washer
Need parts for pump
  • 109 Answers
SOURCE: on a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Posted on Mar 27, 2009
  • 28 Answers
SOURCE: I need the owner's manual for Generac Power Washer
Here is the link for your machine.
http://www.generac-portables.com/document/index.cfm?doc=1439_0EN3W_LO.pdf
Posted on Apr 11, 2009
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
  • 384 Answers
SOURCE: I have a Generac pressure washer, model #01450-0,
Take a small diameter wire and poke thru the discharge hole of the spray head to clean out.
Second time in 6 months that I had the same problem. The problem is alway in the spray head.
Posted on Jul 24, 2009
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
How much oil do you put in the pump for a generac pressure washer model # 01676?
Check and see if there is a sight glass on the side of the pump. If there is, just fill it until the oil shows up about half way in the sight glass.
Sep 23, 2012 | Generac Generator 5989 2,700 PSI 2.3 GPM...
How to replace piston rings on honda 6 horse motor
you need to remove the pump then the end cover from the engine remove the cylinder head the unbolt the connecting rod push out the piston hone cylinder and then wash the motor out with soap and water i use tide clothes soap and hot water put it back to gether now why does it smoke check the head gasket the over head engines blow head gaskets and **** oil from the crankcase
Aug 06, 2012 | Honda Garden
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Have a Honda Gc series 2.0 Gpm 4.0 hp gas powered pressure washer model 01195-0 that the pump has went out in and am having problems finding parts ( seals and unloader valve ) I have googled but no luck...
Honda has nothing to do with this pressure washer, other than it has a Honda motor. It is made by Generac. The pump is a cheap pile that can be replaced with a horizontal mount AR Pump for a decent price. The pump that came on the unit is not worth rebuilding. Try looking for an AR Pump RMV2G25 as a replacement.
Apr 01, 2011 | Honda Garden
Pump appears to be shot in Generac 2.3 gpm 6hp Briggs-powered pressure washer. Anyone know how to diagnose pump problems?
Mine blew up. The OEM is ****. Went on-line to buy a similar but more powerful pump. There are lots of pumps that are an easy bolt on. It's mostly standardized. Google "pressure washer pumps"
Apr 29, 2010 | General Garden
I have a Generac MC660 pressure washer with a chemical injector on it The head bolt has broken where it bolts on to the pump. Do you carry parts?
This is a Help forum but you should be able to find a service dealer from Comet. Here is a link to their web site. LINK
Jan 26, 2010 | Comet BXD2527 Pressure Washer Pump
I have a Generac pressure washer, model #01450-0, with a Honda 5hp motor. The motor runs fine, but the pressure hose pulsates as if the pump is intermittently making pressure, and the pressure out of the...
Jul 23, 2009 | Garden
On a generac pressure washer that works fine.
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
I can't find an oil drain plug on a honda 5.5hp engine.gvc 160.
The engine drain plug is on the main (square) base part of the cylinder block. I think it is 10mm. There is a compression washer to seal it aswell so it might need a bit of extra pressure to start it undoing. This should drain your block almost completely.
For diagrams go here, you will need the engine serial number and prefix.
http://www.honda-engines-eu.com/en/welcome.html
For manuals go here,
http://www.honda-engines.com/Engines_owners_manuals/own.htm
Nov 13, 2008 | Garden
Garden Logo
42 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
