When booting the computer, there's a beep coming from the pc. how to disable?
U know when the big gateway sign comes up when starting u'r computer, well it would make this annyoing beep sound once while starting. how to get rid of this sound comming from the pc?? i use window 7 home premium 64 bit
  • 3 more comments
  • sandykafri Jan 03, 2013
    wait i meant the cpu box not the pc!the sound comes from the cpu! btw i don't have speakers set up so there shouldn't be any sounds.
  • Steve Sweetleaf
    Steve Sweetleaf Jan 09, 2013
    That beep is just a turning on beep most pcs do it. unless its constant.. there is a mini speaker in your pc for these beeps so when something is wrong it will give you a beep code so many beeps mean certan things.
  • Steve Sweetleaf
    if you want to disable it heres how.Go to Start-> Control Panel-> Double Click Sound-> select active speakers->Properies ->Levels tab->Adjust the slider for PC Beep to control the Volume when AC is plugged/Unplugged. This has worked for my HP.
  • sandykafri Jan 10, 2013
    i tryed that but the promblem is that i don't have the "pc beep" volume control!
  • sandykafri Jan 31, 2013
    the model of my computer is Gateway DX4300-03 (PT.G830X.003) PC Desktop. now how would ya disable it?
  • 1,147 Answers
You should not disabkle the beeper it is there for reasons like to give you warning beeps when ram or something is bad..the speaker is inside of the pc..
Posted on Jan 03, 2013
  • sandykafri Jan 09, 2013
    true but is there a way to disable it? just want to know. wanna disable it for a while :)
3 Suggested Answers
widyo15
  • 97 Answers
SOURCE: My Gateway desktop locks up
please use mozilla firefox instead of internet explorer it might help...
Posted on Sep 03, 2010
  • 142 Answers
SOURCE: after upgrading my acer x1200
Here you go: http://global-download.acer.com/GDFiles/Driver/Chipset/Chipset_NVIDIA_1.81_Vistax64_A.zip?acerid=633819402516909459&Step1=DESKTOP&Step2=ASPIRE&Step3=ASPIRE%20X1200&OS=ALL&LC=en&BC=ACER&SC=PA_7. From this download unzip and install the LAN drivers then it should properly detect your cable.
Posted on May 14, 2011
My computer got tipped over and won't boot up It beeps 4 short beeps and nothing happens.What does the beeps mean? It's a gateway dx4870-h with motherboard IPIMB-AR Rev:1.02a
The beeps mean that something has come unplugged from the motherboard, likely the video card or memory. Check that all the cards are plugged in fully, and you will likely be fine.
Dec 21, 2015 | Gateway Computers & Internet
Black screen blue box saying
some one must have put in a boot password to your laptop,
follow this:
When booting up, enter your BIOS setup (usually by pressing the F2 key at the appropriate time).
Locate the BIOS Password section and turn the ON STARTUP password to off. There is no standard setup for BIOS, so I can't give you exact instructions.
If this does not work, try:
remove cell & start your pc you will here beep...beep...beep...
then turn off your pc & restore your cell.Start your pc and
password is removed.
there is a battery on motherboard,a button cell,you can try removing that and start computer, then put it back, bios settings will be lost.
you can also try removing any hardware like ram,if you have two,when system is off,turn on , it will prompt for changes , enter bios and try remove password.
Dec 15, 2013 | Gateway LT2001u Netbook
I turn the power on and my light stays yellow and the fans work but it beeps
The beeps you hear are BIOS Beep Codes and tells you what problem is keeping the computer from booting. We need at a minimum, the computer make & model or the motherboard model #. If you also know what BIOS it uses (Award, AMI (American Megatrends), Phoenix...etc), this was displayed during the boot process when the computer worked if you happen to remember it.
Once you know this we can find the code that tells what the problem is.
Oct 28, 2013 | Gateway 506GR PC Desktop
Hard drive is disabled on gateway SX2802
BIOS is the system setup that you have to press a F Key or other special key to enter. There is a post / boot / main screen(s) that comes up prior to going into Windows.
More details are required. What is on the screen that led you into BIOS?
Nov 23, 2012 | Gateway SX2802-07 PC Desktop
The yellow light comes on inside but the computer won't come on neither does it beep?
First remove any power cables and batteries(if laptop) from your system and hold down the power button for 15 seconds.
Plug the power cable back in & attempt to boot.
If this does not solve your problem then you will need to remove all non-essentials from your system.
If laptop, this simply consist of battery, ram, optical drive & any other removable bays or devices. Unplug all cables except the power cable & attempt to boot.
If desktop, you will need to remove any cables plugged into your computer except keyboard, mouse, power, video, sound, & network cable. Open the case & remove any PCI cards, except video cards, unless you have on-board video, unplug the data & power cables going to the optical & hard drives. Now attempt to boot. If you have no luck you can remove your RAM sticks & try again. If you get an error beep warning you about no ram then you might have a bad ram stick. If none of the above works then you may have a bad power supply or motherboard. Power supplies are pretty easy to test with tester or use a spare.
Jul 16, 2012 | Dell Computers & Internet
Keys to use at boot time to access bios
It isn't keys, 3glarry, it is key.
It is either the F1 key, or the F2 key.
This key should be displayed when the Gateway logo comes up.
Gateway logo appears? Look quickly at the bottom of the screen.
Preferred method to enter BIOS Setup is this;
As SOON as you press the Power On button, start tapping on the appropriate key. Tap in 2 second intervals.
You may hear beeps. These are Stuck Key Error Code beeps.
You know they aren't real, because it is you that is doing it. Not a stuck key on the keyboard.
Why use this method?
Because the window of opportunity to enter the BIOS Setup utility, goes by F-A-S-T!
Now, may I ask what you are doing in the BIOS Setup utility? Post back in a Comment.
Regards,
joecoolvette
Jun 23, 2012 | Gateway Computers & Internet
I have a Dell Latitude C610; after initial 'DELL' screen comes up, the laptop gives one 'beep' then black screen and nothing more- power's still there; can get into setup and boot...
This chart details the specifics of what each 'beep code' means. Usually the codes come in series of 2-3 beeps not just one.
http://www.nullamatix.com/dell-diagnostic-beep-code-troublshooting-chart/
You should also make sure the 'dummy' stuff is done, like remove any floppy disks or CDs from the drive if you have one, and remove any USB drives from the laptop as they may try to boot off of them and not be able to. If you've done that, then check the chart in the link for further information. Sadly a non booting, beeping computer isn't a good sign. If I can be of any more help, please let me know.
Hope this response helps you out.
Best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Dell Latitude C610 P3 Notebook
I was getting the blue screen for a few months, and now when I power my Gateway GM5084 the lights come on and I hear it running but nothing comes up on the monitor. It's like it's not connecting...
First I would try a different video card to see if your video card is faulty or not. If you still can't seem to get any picture it could be that the power supply on your computer is starting to fail and not providing enough power to the video card.
Usually your PC will beep if it is a video card issue so if you don't hear beeps I would guess the power supply is the culprit. A replacement power supply is not that expensive and is quite easy to install as well.
May 18, 2011 | Gateway GM5084 PC Desktop
GATEWAY GM5094E Athlon dual core, NO POST TEST BEEP-NO BOOT SCREEN, fan worksHD light comes ON, but no boot.
Being no test beep, I'm saying motherboard. Try removing & replacing ram sticks to see if it boots. Other problems may be simply a bad power supply. Did you test the video with a vid card another vid port? Might want to try that first. It could be you lost the video.
Apr 15, 2011 | Computers & Internet
I am having problem with my computer. Initially it started with a Beep everytime I use to boot the computer, it gave me a message after the beep that " Your password expires in 14 days do you want to...
hi nitind
  • It's not big problem
  • re-boot ur system
  • you r telling you r upgrade your pc,so it supports windows7 too
  • put a new copy of windows 7 original
  • if not means disable the windows update after installing ...
  • before the problem may arise due to corruption of files or password is not a valid one ..
  • so put a fresh copy of windows in which drive already you have os...
  • other drive data must be safe...
  • keep antivirus active this must be helpful for your pc ...
Dec 25, 2010 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
