Question about Toshiba 40E210U 40 in. LCD TV
How to access digital audio selector - Toshiba 40E210U 40 in. LCD TV
The input selector knob won't change the input and I have no sound.
Your receiver has gone to receiver heaven. With labor costs being what they are and the good inexpensive electronics available, it might be better to replace than repair.
Sep 06, 2015 | Audio Players & Recorders
Want to run the audio of ELEFC461 46 inch HDTV through a Bose stereo
If your TV has digital out and Bose has digital in, connect the same or if out and in is with RCA, then connect the audio out of TV with the Aux in of the Bose and make sure that while playing, input selector is on Aux or there will be no sound.
Apr 05, 2012 | Audio Players & Recorders
Cannot manually adjust or access menu on Sony Dvcam DSR-PD170
you need to set the auto lock to centre position , and then you need to check the camcorder,if still it doesnt work then you need to take the camera to a good engineer for repairs
Jan 03, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Nov 02, 2008 | Sony DVP-NS57P
Manual input selector problem
maby a bad cirket .i have the same reciver but mine dose not have this problem.
Jul 11, 2008 | Technics SA-DX930 Receiver
go to any hardware store & pick up an universal remote that you can program for your dvd.
I am trying to connect my Samsung 56" DLP HDTV to my JVC THD50 home theatre system, all the speakers are hooked up correctly but I can't source from the tv to the speakers correctly, I connected a...
On the rear of the receiver you will notice several AUDIO IN connections. Make sure that the AUDIO IN and the receiver's input selector match (for example, if you are connected to AUDIO IN for the VCR section, the input selector on the FRONT of the receiver should also be VCR). Also, make sure that the input selector you are using is set to "Digital Audio" or a digital audio enabled equivalent and NOT analog. Check all connections again to make sure you have not grounded any speaker wire. Check to see if "MUTE" is on TV or Receiver. Try another audio in source just to make sure the speakers are connected properly. If that works, you can pretty much decide that it's either the input selection is wrong or the audio source is not set to digital 9also check to see if PCM is enabled and try setting to "AUTO" if you have that function. If you have option on receiver for speakers A and B, make sure selection matches your wiring.
Apr 03, 2008 | Audio Players & Recorders
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
Download problems
the camera is off need to on the camera / before plug the camera see to it that the mode point to arrow for viewing to detect by the computer ./ do not point the selector camera auto or manual, video. the PC connot detect.
Jan 01, 2008 | Fuji FinePix S5000 Digital Camera
Toshiba 40E210U 40 in. LCD TV Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
