My amp wont turn on - Audio Players & Recorders
  • Dick
    Dick May 11, 2010
    More information please.
    Problem Solver:
  • 10 Answers
First check the fuse located on the back and if your receiver does not have a fuse on the back then open the receiver and check the fuse inside. 80% of the problems are fixed by a fuse replacement
Posted on Jan 19, 2009
Model GW712av wont agitate
Will the bowl turn with no water in it,
If not turning the bearings are seized and rusted.
A bearing and seal kit is needed for your machine.
Aug 15, 2012 | Fisher and Paykel Washing Machines
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
I have power , but the amp wont turn on
Where is your ground located?
It never hurts to put a beefy ground on an amp. If you do have it grounded take the bolt out use a wire brush on the bolt and on the surface you are grounding to. Also check our remote wire(blue). The purpose of this wire it shuts your amp down and turns it on when you turn on the head unit.
Apr 04, 2010 | Kenwood KAC-9104D Car Audio Amplifier
Wont turn on every thing is hooked up right pluged
A PLYE AMP IS NO GOOD AND ITS PROBABLY BLOWN SORRY FOR THE BAD NEWS
Feb 09, 2010 | Pyle PLA985R Car Audio Amplifier
Wont power on
Ssometimes the antenna wire is not enough to turn on the amp , some cars use relays in thier power antenna turn on set up which require low 500 ma 's . hit the amps turn on post with 12 volts directly from a jumper wire with alligator clips from main poower wire , if it still wont tunr on the amp the amp may be faulty , also check amps ground , metal its grounded must be free of paint , undercoating rug ect ....
Nov 17, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Tappen gas range thermostate wont turn oven off
The T-stat is broken & needs replacement. Most Mfgs have exploded views of equipment listed on their websites & this is an easy fix if you have more than basic mechanical skills. 1st & foremost, find the breaker panel & turn the breaker for the oven OFF before attempting any repair. Parts can be located either on Tappan's website or a local appliance parts house.
Jul 09, 2009 | Tappan TGF320 Gas Kitchen Range
Amp wont turn on due to thermo light is on.
is it mounted in a place with good air flow?  Have you blocked the bottom vents?  Can you mount it in blocks or use longer screws and stand offs?
Mar 31, 2009 | Car Audio & Video
171 people viewed this question
 Grubhead
Grubhead
