Question about HP Pavilion a1610n PC Desktop
Hp pavilion a1610n post beep no video
The is one post beep it repeats every 4 seconds same beep with no monitor display at all. I cannot seem to find a correct problem for this post beep. I have an asus mobo ( A8M2N-LA).
  • HP Master
  • 1,147 Answers
Remove your ram clean it clean the slots reinsert ram and retry..
Posted on Jan 03, 2013
  • 4 Answers
SOURCE: HP PAVILION 760n
tell me if there is something i need to know like: what were the things that you've doing with your computer before the problem happened?? are there any recent hardware/software changes?? tell also your OS- is it XP or Vista...
first, let's try to check if the problem is with the monitor or not,okey? try unplugging the monitor blue connector at the back of the tower.and make sure that your monitor is turned-on.If you can see a colored bars displayed.you monitor is okey.if not, try a known good monitor...if it woks the problem is with the old monitor.(resolved)
2 (if not)
Now, complelely turn off your computer and try reseating all the cables, and your hardware components such as memory,video card,IDE cable and so on. but before doing so, unplug the power cable and then push the power button to drain the power.after reseating everything, plug back the power cable and turn on computer.try listening to the tower,tell me if you can hear some beeps also.
if no video issue is still there, try putting a known good video card if you have any.if a known good video card works then the problem is with the old one..
if the problem is still there after everything that you've done try calling the manufacturer. this is lead to a motherboard problem but try to call them first.
Posted on Jan 17, 2008
sodeep
  • 3267 Answers
SOURCE: all update downloads fail
Is the PC still under warranty? If it is then give them a call to fix it free. Otherwise repair the OS by the restore/emergency disc provided by the manufacturer. Make sure your OS has been activated by the manufacturer. Then try updating the PC.....sodeep
Posted on Apr 21, 2009
  • 477 Answers
SOURCE: I need bios version 3.0 for motherboard A8M2N-LA,GL-6
Hello, go here this is the only place I found the 3.0 version. scroll down on the website fill in your mail address and get a download link to your email.
"You can create a new account for free. Members have unlimited access to all files.
If you want to download only this one file, we will send a download link to your e-mail."
Posted on Aug 17, 2009
  • 211 Answers
SOURCE: HP Pavilion a1610n will not boot up. I get the
If you have tried another monitor and result is the same, then it's a faulty graphics card.
If graphics card is sharing system memory, then you might need to replace ram to get it work again.
Posted on Sep 03, 2009
  • 567 Answers
SOURCE: HP pavilion A750w starts up, but doesn't seem to
Hi there you need to make sure the monitor is properly connected and make sure you install the drivers for the new video card.If you still have the problem you should open the computer and check the memory by taking it out and put in into another memory slot on the motherboard.If you have more than one memory in the computer please take them out one at a time and restart the computer if that does not work you should replace them you new one that is compatible with your computer.
Posted on Jun 13, 2010
My hpw1907 monitor says no input and wont display anything. The cpu also makes 1 beeping noise that last 1 second nd doesnt come back
A one second beep from the computer is standard for a proper boot.
Do you have a TV that you can plug your computer into to see if it is posting video? That would be the easiest way to test if it is a computer or monitor thing.
Jan 20, 2014 | Computers & Internet
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Instructions how to insert unlock code for radio Holden Barina. I have the code just not sure how to input it
If your radio is made by Blaupunkt ( As most Barina radios are ) then here are your instructions.
If yours is a different make then please post a new question quoting the radio MAKE & MODEL
HOW TO ENTER A BLAUPUNKT RADIO CODE
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Jan 16, 2011 | Blaupunkt Car Audio & Video
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
THE BIOSTAR G31-M7 TE MOTHERBOARD WONT START UP.IT COMES ON BUT WONT POST OR SHOW ANYTHING ON MONITOR
Good day sir, hi. you need these 7 things to make your pc start, make sure they are good.
first unplug your pc. open the side panel to access the motherboard. Remove all connections to the motherboard.
  1. Remove and check the memory module, make sure that the memory terminals are clean, you can use an eraser to clean the contacts. much better if you have new ones. or test the memory modules on another PC to confirm that they are good, then snap it in place, you should hear clicks as you place it on the slot.
  2. Clean the memory slot with a clean paint brush, there should be no foreign objects inside the slots, visual inspection is necessary.
  3. make sure you PS is good. Plug in the 20/24 pin connector and the 4 pin 12v connector firmly.
  4. Make sure that the processor is installed properly. the fan is connected on the fan power port.
  5. connect the monitor to the vga slot, (or if you have graphics card)
  6. connect a keyboard,
  7. and a pc speaker (or the thumb speaker)
Power on your PC.
monitor your PC speaker.
You should hear a beep, (good) one long and 2 or 3 short beeps, problem with the display card, continuous beeps, system board cannot detect memory.
monitor your keyboard.
You should see 3 sets of led light, numlock+caps lock+scroll lock, and a few seconds, 1 led light, the num lock only.
Dec 14, 2009 | Biostar G31-M7 TE Motherboard
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
thnk you.
Nov 29, 2008 | Computers & Internet
Philips monitor
Sounds like you have a bad inverter. You will need to open up the monitor to get to the screen to access the inverter board and replace it. If you are handy you can do the job yourself but if not then you will need to take it in to a computer repair shop to have it serviced. Depending on how old this monitor is, the cost of the repair maybe prohibitive.
Mar 12, 2017 | Philips 190CW8FB LCD Monitor
Failed POST
Foxconn uses the Award bios. One beep repeating means, check for improperly seated or missing memory. You can find that here. http://bioscentral.com/beepcodes/awardbeep.htm
Remove your memory & re-seat.
Mike
Mar 21, 2008 | Foxconn 761GXK8MB-RS Motherboard
HP Pavilion a1610n PC Desktop Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
