Question about Whirlpool WED5300S Electric Dryer
Whirlpool Dryer(WED5300SQ0)won't start
Black plastic latch at top of door ridiculous loose, I bet broke. How do I open top to see if this is the problem? Is probably something as simple as that, It work fine yesterday.
  • linda_barlow Jan 19, 2009
    Great! I have it opened and will remove part.(3406107) How do I release the part from the wires?? Thanks
    President:
  • Whirlpool Master
  • 2,651 Answers
Remove the lint filter, youll see 2 screws, remove the screws and with a small putty knife you cant pop the top using the clips approx 6inches in form both sides where the top meets the front panel, the top will then lift back giving you acess to replace the switch part number (3406107), very common incident
Posted on Jan 19, 2009
1993 Chevy Corsica Door Won't Open
Yes, Ray, remove the door panel...I don't know any other way to get to the door latch. With the door not opening, 2 choices: you can destroy the panel by cutting out or tearing off part of it-kind of around where the door latch is. Or you can remove the four bolts to the driver's seat, pull it out the passenger side, then you would probably have room to get the panel off. You might want to figure out how to get the panels off by taking off the passenger door panel, where you can work and see it. It is actually pretty easy. A few screws, one behind the inner door handle, a few others-look around. Armrests or door pulls have larger screws. Window crank handles are retained to a short shaft by a wire spring clip. There is a cheap hand tool for removing this clip, purchase at any parts store. Get all the screws out. then slip a thin blade screwdriver or putty knife at the bottom of panel, and pry out-there are about 10 or 12 plastic push button pins around the bottom and up the sides part way. Get the screwdriver close to them and pry outward, you can pop them out of the holes they fit in, in the door frame. Once you get them popped out, each one will make the panel looser and looser, when all are loose, panel will be floppy-pull out from the bottom and lift up-up so the panel lifts out of the window channel. there, done. If any plastic pins broke, don't worry, the others will keep the panel good and secure to the door, or you can buy those pins at parts stores or grab a bunch at salvage. If you decided to just rip the door panel off around the latching area, look for another panel at salvage.
Okay, with no panel in the way, one other thing: the plastic water barrier shield, a piece of thin plastic sheeting glued to the door frame behind the panel. Peel it off as necessary to reach into the latch. Trip the latch to open the door. Both the outside handle and the inner handle operate the latch by rods. The small rods are retained by small plastic clips. Maybe your rods have slipped loose. Also check if the lock rod is unlocked. Sometimes, the lock won't fully release. Keep working at it till you get the door open. (Don't put the panel back on till you know the door will open and close.) You should be able to see why the latch won't release. If you see nothing wrong, spray the latch liberally with a penetrant, like WD40, spray it anyway to get past years of dirt and gunk build up. Whatever is broke, replace from salvage-the latch, handles, rods, etc. Sometimes the rods can get bent and the handles won't work.
Hope you get it, let me know. Post back if further questions on this.
Feb 01, 2014 | 1993 Chevrolet Corsica
Driver side door latch broke - won't open from inside. probably cable broke
You're probably right. But it may have just come loose. Either way, you'll have to remove the door panel to find out. Take the screws out of the door panel (usually in latch and pull handle) & pop the door panel off carefully do as not to damage any of the clips. Also, if you have manual windows, pop the ring off from where the crank handle goes into the door panel and pull off the crank handle. If you have power windows, just disconnect the wiring harness. If the cable just came loose, just reattach it. If the cackle broke, you can find them online or in auto parts store for 20-30 bucks. Good luck!
Jan 20, 2014 | Car Audio & Video
Emerson microwave door latch
I have an Emerson MW8999RD that all of a sudden yesterday wouldn't latch. I don't think you have to, but I took the door off (three screws hold the case on which needs to be removed to get at the top hinge). Then I took off the inner plastic picture frame - pretty easy with a thin blade to move the fragile tabs. Then I removed the metal frame that has the little microwave blocking holes. This was the hardest part because the plastic retaining tabs are even more fragile and I broke one. Then I found the loose spring due to broken plastic hook as described above. I was able to make a new hook by simply looping a small zip tie where the old plastic hook tip broke off. Now works great!
Aug 22, 2013 | Microwave Ovens
The handle opener on my my Kitchenaid whisperquiet dishwasher is completely loose and I can't open the dishwasher to remove my clean dishes. What can I do???
The idea is to lift up on the part of the latch that is fixed to the body of the washer. The door part of the latch slides under this peice. If the handle mechanism is broken, it will not depres the door part of the latch to allow it to open. therefore, we have to pickup the latch part fixed to the body.
To get the door open, take a clothes hanger and cut off a 12" peice with a pair of pliers. Bend the last 1.25" at 90 degress angle. Make another bend about 4 " from that to make another 90 degree angle. This will give you leverage. Insert the first bent end between the top of the door and the counter. Rotate it so that the end is facing down. Feel for a metal plate. When you hit the plate with the probe, turn your hanger so that it lifts up the plate and simultaneously pull on the door handle. The door should come open.
Now you have to get the handle repaired, but at least you know how to open the door.
Oct 25, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
2002 Chevy S10 Third Door Won't Open
I have a 02 s 10 with a stuck bottom 3rd door latch. I took my seat balts loose removed the door panel,also removed the plastic latch yoy use to open door, the top latch was alredy opened and I put a needle nose vise grip on the lever going to the bottom I used to much and broke the little plastic retaing piece that holds the lever.I looked inside door with light saw my latch was in open pos and took pry bar to pry botton door from inside,once opened i used a 10 mm 1/4 in drive to take out 4 bolt's to latch.removed latch placed in vice and heated with burnsomatic torch,the latch is coated with a plastic so i burned it all off with vice grip on the lever to open and pliers the work the part that catches door striker I kept working it until it freed up then put antu seige on put back in truck. I recomend buying a new latch and put anti seize on it. that's my plan but at least it's working for now. or get a good used one from a junk yard. you can e mail me at earltoni@hotmail.com for ant Q's
May 21, 2010 | 2002 Chevrolet S-10
Can,t open gas tank latch
The cable hooks up to the latch under your left foot and goes back to the latch on the gas fill door. I believe you can take the trim loose from the trunk to see what the cable is doing. May have snapped or something on the latch near the fuel door broke. You should be able to manually open the door.
Oct 10, 2009 | 2001 Honda Civic
1992 Ford Explorer Sport. Outside door handle not
Door handle seems loose and not connected? Then the plastic clip broke inside the door. Take off the door panel, 3 screws, and door lock cap and plastic insert around inside door handle. pry around the bottom first, and go up, when you reach the top, pull up, please be carefull to not break any more plastic. you will see a squarish opening midway up the door toward the latch. reach in and pull a rod toward the opening. You see a broken piece of plastic on the tip? if so take it off and get the replacement part for it at an autoparts store, install the new one and your set. I have broke to many of these so i ended up bending the end of the rod and using a nut to hold it in.:]
Jun 20, 2009 | 1992 Ford Explorer
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool WED5300S Electric Dryer Logo
488 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
