Question about Acer TravelMate 2201LCi Notebook
Load Error I have 2 acer 2201lcs and they have both gone down with the same error. every time i switch them on they say "load error, press any key to reboot" when i do this they just come up with the same error. Any suggestions
  • richard steabler Jun 25, 2007
    thanks for that, unfortunately i only have the recovery disks which i have done a number of times with the same result and same error. i do have norton go back on my laptops any more suggestions??
    President:
  • 2,961 Answers
This message normally relates to norton go back corrupting the master boot record, i have had a few occasions of it, you will need to set your laptop to use the cd drive as first boot device (press F2 or Del on start up)in the advanced cmos settings, save and exit. Insert your windows cd in your drive and boot up the notebook and when prompted press enter to boot from cd and when windows installs the system files you will have a choice to press 'R' for repair or enter to install windows, if you press 'R' you will have to choose the operating system, just follow instructions and then if a password is required just press enter and then in the next prompt type 'fixmbr' and press enter, or if you choose install windows will see you have an operating system installed and ask if you want to format and install or repair system files.
Posted on Jun 25, 2007
SOURCE:
My computer dont display any thing . But when i remove smps supply cmos bettery and ram. Then put in each place to run the computer. And gives cmos checksum error. What i do as that.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps
Apr 29, 2012 | Intel Computers & Internet
CMOS Checksum Erro
hope this helps you
Mar 15, 2012 | Gigabyte GA-8I865GME-775 Motherboard
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
My acer aspire one d257 wont load anything at all as soon as you switch it on it comes up with error it is only 7 months old.
Hi
you could try pressing the power on key then straight away press the F8 key a few times
this may take you into the repair options it you can try the last good known configuration
or the repair my computer
if this does not work and
if there is nothing that you need saving on it you could try this it may or may not work
press the power on key
then straight away press the ALT+F10 keys a few times and this may take you into the factory reset options box
sometimes it may ask for a password
the default acer password is 000000 thats 6 zero,s hope this helps you
please let us know if it did
many thanks
Aug 04, 2011 | Acer Computers & Internet
Your chassis has been opened. Press F1 to continue How to clear warning
hi
press f1
then go to pc health on bios, chassi option press enter key .choos e reset the press f10 save yes
Feb 22, 2011 | Acer Veriton M661 PC Desktop
L S or L5 error code on Calypso top load washer (Color - grey)
LS Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Load error
check your hard drive
May 09, 2008 | Acer Aspire 3000 Notebook
Acer Load Error
Detect the Harddisk in the BIOS setup & if it is detected then also it displays in the same manner then do one thing replace the BIOS.
Sep 17, 2007 | Computers & Internet
Acer TravelMate 2201LCi Notebook Logo
50 people viewed this question
Ekse
Alun Cox
