My MacBook Air is not booting up . It says You shutdown your computer because of problem .. It says u click open or wait but if I do either ways it does not boot up
    Genius:
  • 1,669 Answers
Try going to this site: www.ehow.com/how_6924064_reset-frozen-macboo...
or
· www.dummies.com/how-to/content/how-to-use-st...
Posted on Jan 02, 2013
4 Suggested Answers
zohail
  • 1223 Answers
SOURCE: boots up .. on logon goes into shutdown ... safe mode no better
pls restore ur OS like this see if it helps pls le tme know if i can help more b4 rating me and Rate me FIXYA if solved
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Posted on Mar 19, 2009
  • 56 Answers
SOURCE: HP dv9000 screen shutdown
Power controller circuit on the motherboard needs repair by pro.
Posted on Oct 12, 2009
  • 77 Answers
SOURCE: computer boots fine but clicking on internet
its the OS issue, reinstall the OS
Posted on Dec 24, 2009
Why does my macbook air keep shutting randomly?
Sounds like a sticky key that thinks it has been pressed
Nov 14, 2014 | Apple MacBook Air
Having problem to shut macbook
Click the Apple logo at the top left hand corner of your screen and select "Force Quit". On the small window that pops up, select the trouble app and click Force Quit. If the app does not close, hold down the power button until the screen goes black. This will not harm your computer (since it's a Mac) and you can boot it back up afterwards.
Nov 06, 2014 | Apple MacBook Air 11.6" (TD73785W) Mac...
Can not click on icons
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Dec 25, 2012 | Apple MacBook Air
Force eject CD from Macbook
A few ways of doing this
restart mac and press down the trackpad after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
Finally what to do is try pick up your macbook tilt the macbook to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
Hope this helps.
Dec 19, 2011 | Apple MacBook Mac Notebook
I cannot figure out how to get skype on my macbook air
copy and paste the following link into your browser
http://www.skype.com/intl/en-gb/get-skype/on-your-computer/macosx/
click the "Download Now" button (it's green)
once it has downloaded, depending on the way your MacBook Air is configured, it may start the installation automatically. If it doesn't, then open your downloads folder, and double click the Skype installer (named (Skype_2.*****.dmg the *'s represent numbers) and follow the instructions on screen
Jun 15, 2010 | Apple MacBook Air
Problem logging on macbook air
try zapping the p-ram like this: power up, listen for chime, hold down control command P and R then wait for second chime. then release see if that fixes it.
May 05, 2010 | Apple MacBook Air
Hello, I'v got a MacBook Air, and it won't turn on as it goes: on, the Apple logo shows, the waiting wheel spins and then turns off again, and keep doing this till i shut it down for good... it won't turn...
Try:
1. Turn your MacBook Air off by holding down the power button for about 10 seconds.
2. Hold down one of the Shift keys and press the power button for a few seconds. Keep holding the shift key for about 1/2 minute. This will start the machine in "Safe Mode." It will check to make sure there are no errors on your hard drive and do other tasks to hopefully fix your problem.
3. Once you see your Desktop (if you do), click the Apple menu and click "Shutdown".
4. Start the computer normally by holding down the power button for a couple seconds.
If this doesn't work, you may need to reinstall the operating system. On a MacBook Air, that's a bit more complicated. You'll need either the external DVD drive (an optional purchase for the Air) or another computer. Your computer manual explains how to install software on that other computer (may or may not be necessary) so that you can use that computer's DVD drive to put the disc in and reinstall Mac OS X operating system.
Good luck! Please let us know if you have further questions or problems.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Apr 21, 2010 | Apple MacBook Air
FileVault recovering disk space for hours. No reboot/shutdown.
forcefully shutdown the system and restar the system and reset the pram and smc.this can sol the issue
Feb 23, 2010 | Computers & Internet
I can't get the mb397g/a working on my apple HELP Pz
Try this procedure with the Macbook Air SuperDrive
and then click the Apple link below to follow the remaining recommended steps with for troubleshooting your Macbook Air SuperDrive.
Here are some steps you can try to resolve the issue:
• Make sure your SuperDrive is connected to your portable.
• Properly shut down your Macbook Air
• Once it is is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Macbook to start up.
Apple Support Link:
Troubleshooting the MacBook Air SuperDrive
This process is supported by Apple, but if it does not work, just let me know.
Regards,
-Terry
Oct 30, 2009 | Apple MB397G/A MacBook Air SuperDrive
Wont sync to my computer and the computer will not recunize it how do i fix this
Go into the control panel, click on system, then device manager and then search the list and see if any red or yellow exclamation marks are present. If none are than unplug all your USB cables going to the computer. Next open up Universal Serial Controllers and uninstall all the devices listed, close the open windows and shutdown the computer, wait 10 seconds after complete shutdown and turn computer back on. Let windows boot completly up and it will reinstall all the USB drivers again and probaly have you reboot the system. After it boots back up install your software to your player, after installed than plug your player in and it should work. If it works OK than plug the USB devices you unplugged earlier back up 1 at a time, windows will detect it and load the required drivers again for each device you plug in. After all your devices are re-installed do a shutdown, wait 10 seconds and reboot. Everything should work normally now.
Jul 04, 2009 | Coby MPC895 MP3 Player
Computers & Internet Logo
David Payne
David Payne
