USB Mass Storage Device(Kingston DataTraveler G3 USB Device)
  • 27,725 Answers
You have neglected to post a detailed problem !!
A few important bits of information about using faults and fixes on usb drives w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 If you need more help with this post a reply Hope this helps.
Posted on Jan 02, 2013
SOURCE: i cannot open my usb mass storage device
http://www.winhelponline.com/articles/223/1/Open-With-dialog-appears-when-double-clicking-on-a-mapped-network-drive-in-My-Computer.html
Posted on Jul 30, 2009
SOURCE: Using the USB cable I connected my HP Simplesave
Be sure you close any program that has accessed the drive.
Posted on Jan 12, 2010
aviral_srms
  • 1216 Answers
SOURCE: kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Posted on Feb 14, 2010
SOURCE: my 8gb kingston datatraveler apears good but cant open at all
may be toomuch virus
Posted on Apr 17, 2010
  • 10406 Answers
SOURCE: My kingston 2gb G2 Datatraveler
Does it work in some other USB port?
Does it work in some USB port on a different computer?
If not, then take a sledge-hammer to it to block ALL future attempts to recover any data from it.
Then, spend $8 to buy a replacement.
Posted on Nov 21, 2010
My flash kingstone 16 g is not accessable how to make it work?
Maybe there is such a kind of bad sectors on the hard disk.
You can use softwares to improve flash / hard drive.
Can be downloaded for free, it's freeware.
I recommend, HDD REGENERATOR, which can repairing without deleting the data (if there is data).
If the flash does not contain data, try reformatted.
Can also initialize from the device manager.
Or if necessary, run FDISK.
Aug 27, 2015 | Computers & Internet
INSTALL KINGSTON DRIVERS FREE
You normally do not need drivers for this device, plug it in and wait.
If you do want me to install drivers I do not do it for free.
Dec 11, 2013 | Kingston 8gb usb 2.0 datatraveler g3...
What is an I/O device error when trying to access my kingston Datatraveler g2 Flash drive and how to fix
the i/o stands for input/output device and the flash drive is one of them,try formatting the drive on another operating system like ubuntu
Sep 17, 2013 | Kingston DTIG3/32GB 32GB DataTraveler G3...
Datatraveler g3 driver
go to start , RIGHT CLICK on My computer the select manage.
In the window that will open choose manage disks and reformat your usb stick (if it's not shown there connect it into another port and repeat )
May 13, 2013 | Kingston 4GB DataTraveler I Generation 3...
Where can I get instruction on how to use your 4GB DataTraveler - G3 - USB 2.0 ?
Hello Gwolk,
The Kingston 4GB DataTraveler Generation 3 (G3) USB 2.0 is a durable 4GB flash memory drive for use with both Macintosh and PC computers. It may be used to transfer files from one platform to another, or to carry files and small applications on a continuing basis. Having no moving parts, flash drives are exceptionally durable and reliable for years of use.Simple - just plug into any USB port
Aug 16, 2011 | Kingston Digital 4GB DATATRAVELER C10...
Can't remove write protection from my kingston datatraveler 4gb g2
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Jul 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove write protection in 8 gb kingston DT 101 G2
also
- Click permissions
hope this helps
don
Feb 12, 2011 | Kingston Technologies 512MB DataTraveler I...
Reporting 0 bytes in disk part
# # Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
Jan 14, 2011 | Kingston Technologies 512MB DataTraveler I...
Computers & Internet Logo
359 people viewed this question
David Payne
David Payne
