No, it will not usually need to be removed. But a special tool is required for removing and replacing the inner tie rods. You can buy this special tool, or have a shop do it.
SOURCE: inner tie rod ends on a 2002 toyota celica
First, you do NOT have to remove the rack to replace the inner tie rod ends. Second, If you want a .pdf regarding the procedure, I'll be glad to send it to you. But, the tie rods just screw off. Whatyou WILL need to do is get a good front-end alignement after you replace the inner tie rod. If not, you will destroy your tires. Alignment is critical to minimize tire wear on Celicas.
SOURCE: I am replacing the inner
You will need sockets of the proper size, side cutter pliers, 16 oz or bigger ball peen hammer and a pickle fork (thing to remove the ball joint) probably regular pliers and a screw driver. You will possibly need new cotter pins and a grease gun. Other tools may be required but I would not lay down on the mechanic crawler until I had at least these items.
How do you intend to realign the front end? If you are going to do this, you will need a $25,000 wheel alignment machine. I recommend you get the alignment done at a shop equipped for this service.
Thanks for your question @ FixYa.com
