Question about HP Computers & Internet
Computer makes many beeps in a row - HP Computers & Internet
  • HP Master
  • 1,824 Answers
Please provide more info about the problem.
When excatly did this start to happen?
When does it beep (What do you do?)
Posted on Jan 08, 2013
What is 3-3-2 beep tone meaning
System doeIf there is one DIMM in the system the memory row/bank may be disabled when there is a memory failure. The system will not boot because it has no memory to use. If the DIMM is replaced with one of the exact same type and size, then the system will continue not to boot. BIOS cannot tell when a DIMM has been replaced with one of the exact type and size, therefore BIOS believes it is still the bad DIMM and will not use it.
Here are two possible workarounds:
1. After replacing the defective DIMM, continue to reboot the system until you hear the "no memory" post beep sequence (3-3-3) during POST (no video display). After three (3) incomplete boots, a "062 three consecutive boot failure. Using default CMOS configuration caches are off" error will occur. At this point BIOS will go back to the default settings and begin to use the new DIMM. However, if you have disabled the 3 boot fail count (this setting may not be available in all servers) in Setup, then BIOS will not turn the DIMM row/bank back on.
-=OR=
2. Remove the DIMM. Power on the system until the "no memory" post beep sequence (3-3-3) is heard. The memory row/bank will now be marked as being empty. Power off the system and put a good DIMM back into the system. The memory DIMM row/bank is re-enabled and the system boots normally.
NOTE: If more than one DIMM (or more than one DIMM set) is installed in the server and one memory (or one memory set) row/bank is disabled due to a memory failure then, the user must go into setup and re-enable the row/bank after replacing the bad DIMM.
Additional information
s not boot after replacing memory DIMM Servers
Jun 11, 2014 | IBM Netfinity 5600 8664 Server
What does the beep sounds on GX670 mean?
When a computer starts up there is usually a POST signal or Beep that indicates all is well (One Beep).
That is standard on PC's and not always used on Portable Computers. More than one beep or successive beeps in a row can be alert of trouble with the CPU, Motherboard, RAM, etc.
May 13, 2014 | Dell Gx-520 Intel Pentium 4 2.8Ghz Desktop...
HP desktop computer makes many long beeps i a row and won't turn on
Those beeps are warning beeps look up what the beeps mean for your machine.
Jan 02, 2013 | HP Computers & Internet
Beeping noise
Ok if you can restart computer,,,when it first starts turning on,,hit f1,,will bring you up to a menu,,may can find prob listed there,,also beeping noise usally video related ,,ddr cards,,open side od computer,,turn it off,,,you will see what looks like cards in a row,,,ddr cards,,pull one out,,,restart,,see iff resolved,,if not repeat,,put it back ,,remove ther,,and so on,,could be bad ddr /ram card,,also hp .com support ,,they can help,,,they have a killer support page,,very helpful,,goodluck
Dec 20, 2011 | HP Computers & Internet
As soon as power is turned on, I get 6 short beeps that repeat
6 short beeps in a row usually mean that the chip on your motherboard that controls your keyboard (A20 gate) isn't working.
First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
In case you do not want to replace that chip by yourself, and after trying other keyboards it is still beeping, then find your local IT guy.
If your system is still under warranty, you should just call provider(seller) of your computer first, as tampering with your computer may void your warranty.
Jul 06, 2011 | SuperMicro COMPUTER Supermicro...
Recently, my car started beeping. The sound comes from the dashboard (somewhere) and there are no indicator lights on anywhere (Check engine, battery, oil, etc). Upon starting the car, a long beep begins...
It could be a fault code being reported
you haven't mentioned a make or model
take it to an accredited service center that has experience on the make and discuss the problem with them
May 27, 2017 | 2003 Ford Escape
I have an IBM Wheelwriter Typewriter Model 674X and it keeps beeping at me when I type. Why is it beeping and/or how do you make it stop?
the beeping is the spellcheck option.. you just have to quit spelling wrong! Just Kidding. The dictionary is limited. You can turn it off by holding the 'code' key while pressing the key that says 'spell' on the top row.
Sep 29, 2010 | IBM Wheelwriter 6 Typewriter
Faulty computer
Hi just read your posting.Now can you tell me why you think your computer is faulty.Does it come up with an error code or is the computer not powering up?If it does come up with an error code there will be a beep and a series of lights will be lit when it is beeping.These lights will be in a row of 8 lights.What I need to know is what lights are lit in this row.Starting from left to right on the row which lights are lit?Is it the 2nd and 4th or the 3rd and 6th -0--etc---?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jul 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Computer will not come on
beeping 4 times in a row is a hardware problem
repalc motherboard if video is intergrated
Mar 26, 2009 | IBM ThinkPad T30 2366 Notebook
Stange beeps
-Reset u r mobile
-Contact motorola care center
Nov 11, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
