Question about Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not start when I press the start button.
Whirlpool dryer model number LER5848EQ2, will not start when I press the start button, I have checked the circut breaker and it is plugged in, I set the timer and all that happens is I get a clicking sound when I press the start button.
  • 61 Answers
Frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Posted on Jan 19, 2009
  • Oscar A. LEBron Dec 12, 2012
    The entire back panel is weld to the side panels. the only access panel on this model is located behind the display panel.
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: Dryer not working at all
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on Jul 01, 2009
How do I fix a Whirlpool dryer that won't start unless it sets for a while?
Hello, It sounds like one of the sensors are bad. This is probably still under warranty, you need to call the cust service or the maker or your dryer, give them the serial number and model. Here is whirlpool cust. service phone number:1 (866) 698-2538
Pls rate my answer, thk you.
Nov 20, 2015 | Whirlpool Dryers
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
We have a whirlpool duet gas front loader dryer and one morning the front panel says control lock?? What's solution for that??
The Control Lock is a child lock option. This prevents the dryer being started or the cycle being changed when it shouldn't. To toggle this off, you need to press and hold the Control Lock button on the WGD9550WL for 3 or more seconds. Other dryers use pressing and holding Cancel or two separate buttons for the feature. The appropriate button or set of buttons will usually have a Hold for 3 seconds label below or on the key in a small font.
The manual will also have the information on toggling the control lock on and off. Most Whirlpool manuals are available here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . Put your model number in the search box and press the right arrow. For dryers the model number is inside the door on the rim of the dryer. If you add a comment with your Whirlpool model number, I will be glad to check if there a different Control Lock option for that Duet model.
I hope this helps.
Sep 07, 2011 | Whirlpool Dryers
My whirlpool dryer start when you press the start button - but as soon as you stop pussing the start button the machine stop and does not continue on it self.
This problem is most commonly due to the motor. The motor has an internal switch called a centrifugal switch that senses when the motor is up to speed.
The second cause could be the start relay (this is present on some but not all models), this is part of the start button you push and is less expensive than the motor, it can be checked with an ohm meter to determine which component is faulty.
If you can send me your model number I can pull up the wiring diagram to determine which type of start component is on your Whirlpool. The model number can be found on the tag just inside the door
Jul 28, 2010 | Dryers
I have a whirlpool model # LER5848EQ2 It was running and stopped. now when I push the start button the timmer runs but the motor wont start where do I look next?
you have a fuse on the blower housing in the back. take back panel off and you will see it its only about 2" long with two wires attached. Have your local appliance tech check it. if its bad replace it
Nov 07, 2009 | Dryers
Thanks
Vic
Jul 01, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
HI yes it could be a fuse its called a thermal fuse located at back of dryer remove back on the left sede on air duct a fuse with 2 smaller blue wirse that should be your problem thanks THE APPLIANCE DOC
Sep 06, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
223 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
