Question about Abbott Laboratories CELL-DYN 1700 Hematology Analyzer
Pre-mixing cup not draining
The pre-mixing cup does not drain and overflows. I can't find any troubleshooting steps in the Operator's Manual for this issue. I would appreciate any troubleshooting suggestions.
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
Can you use a different 2 cycle pre mix after a different one
Yes you can; but it is a very good idea to drain your carburettor(small phillips screw at the bottom of the float bowl, sometimes an allen screw) with the FUEL OFF at the fuel tap at the bottom of the tank. Then remove the fuel line from the tank to carby at the carby end, and drain ALL the fuel out of the tank(ensure to switch the fuel tap tap 'reserve', if applicable). Actually it's a really good occasion to remove the fuel tank completely, and rinse it out with a cupful of the new fuel mixture; but I don't know how committed you are to maintenance...If you don't follow this procedure to separate the two different fuel mixes, you may get partial solidification of some components of the fuel/oil mix. Then again, nothing may happen: but it is better to be safe than sorry!
Mar 04, 2012 | Suzuki RM 250 Motorcycles
Drain stuck in closed position
Generally the drains that are controlled from the
OVER-FLOW do indeed have a rod that goes down
from the face of the overflow... which lifts (opens)
the drain by lifting a hollow (typically plastic) sleeve
from in front of the outflow of the drain...
It is hollow to allow the OVERFLOW to work at all times.
The version you seem to have... WOULD have a
bellows like device that pushes on a plug lever...
More complex... but I seriously believe both may be
serviced through the OVERFLOW
(will attach a drawing below)...
OBVIOUSLY you will want to block the drain before rolling & dropping screws in, on & around the drain HOLE...
Once you see the diagram of the drain MECHANISM...
you will be able to see that jamming in a coat-hanger
was a terrible idea.
You can still most likely remove and repair the
mechanism ... (from the over-flow)
ELSE
You are looking at buying a new one and installing the entire drain from the bottom (hopefully).
Diagram of drains:
Go to Bing homepage
Carnac the Magnificent
Mar 22, 2017 | Maax Plumbing
Where is the engine drain plug?
It is always on the lower side of the oil pan on the "bulge".
Aug 17, 2011 | 2004 Honda Accord
Where is the drainedge for the radioter
For a 2001 Buick Regal GS 3.8 Liter, Supercharged engine:
First, let engine cool some. Second, locate small drainage hole at the bottom left/drivers side, of the radiator. From the bottom of this small drain hole, go straight back toward rear of radiator, then up about 1 1/2 to 2 inches up. (Have a drain pan or pail handy, to catch the old antifreeze.) You'll find a dark colored drain nut. Use a larger, correct sized socket ratchet wrench & loosen this fitting a turn or so, counter clockwise. Old antifreeze will begin to come out the bottom drain hole. The more you loosen the fitting, the faster the fluid flow out. I wouldn't remove the drain plug completely, or you'll loose control of the draining flow rate.
I just changed my anti-freeze just last week. I also changed the 2 large radiator hoses & smaller 2' overflow hose at the same time, as long as I was doing the job. They had never been changed before. I also used new hose clamps & a small packet of "radiator hose grease", from Autozone.. I drove the car up onto front car ramps to make it easier. I used safety jack stands for extra care. " You-Tube" shows some, "how to videos", that are helpful.
The old hose clamps are difficult to get to. (You'll need a few tools, some time & patience.) To get to the upper clamp, near the right/passenger side of the of the car, near the battery, I removed the outer serpentine belt & tension pully. I then removed the factory installed spring tension clamp, with the help of an adjustable battery pliers. The bottom of this hose wasn't too bad to get to. On the left/drivers side of car, remove black air intake box to access upper clamp. Remove the black metal brace bar, the will allow access to the air intake black box.
I also changed the small overflow 2 foot long hose & 2 clamps, that goes from radiator cap area, back to the overflow white plastic tank, close to passenger firewall. I removed the overflow tank to clean it out as well. I drained the fluid & changed the 3 hoses & clamps. I then placed all removed parts back where they belong, including white plastic overflow tank, tension pully & outer serpentine belt, air intake black box & metal diagonal brace, contacting air intake box. I flushed the system with some Prestone Radiator Cleaner & clean water. Start car & get up to temp., then run for about 10 minutes. Let cool, then drain again. I flushed my car at least 2-3 times after this, until the drain water ran clear.
The best price on a 5 year/150,000 mile anti freeze, came from Wal-Mart. I then mixed about 50/50 with Distilled water, as suggested on the bottle. All went well & no leaks! I took my time and did a thorough job. Good luck!
Jan 16, 2011 | 2001 Buick Regal
I want to change my antifreeze in my 2003 merc grand marque. Where is the drain plug on the radiator? Do I pour the new antifreeze into the overflow tank on top when I refill it?
look down at rad from top to get familiar with where i am talking about. now opposite side of the lower rad hose is where you want to go, two styles of rads, one has a wing nut type white plug, and other as 6 sided white plug, unthread with pliers or by hand loosen till desired flow is coming out. fill into reservior or overflow tank to half way and run engine til i reaches operating temperature and you has good heat out of heater, this makes sure all air is out of system, and this is complete ttop up to full and install cap
Jul 06, 2010 | 2003 Mercury Grand Marquis
I NEED TO FLUSH THE INTERCOOLER SYSTEM OUT AND REPLACE THE COOLANT, WHAT IS THE BEST WAY TO DO THIS?
  1. Start with a stone cold engine
  2. Open the radiator cap
  3. Open the radiator drain plug and let out as much coolant as will drain';
  4. Replace drain plug and refill the sytem with distilled water
  5. Run the engine for for few minutes until it is warm (not hot);
  6. Repeat steps #3, #4 and #5 until you've effectively replace all of the coolant with distilled water. You'll know your finished draining the system when only clear water drains out.
  7. Drain the system one last time (now only residual distilled water should be in your cooling system);
  8. **** out all the coolant in the overflow tank (I use a Turkey baster or a huge syringe with a short length of rubber tubing.)
  9. Replace the radiator drain plug.
  10. Add undiluted anti-freeze to the system;
  11. Run the engine to mix the distilled water already in the cooling system with the newly added antifreeze.
  12. Check the antifreeze/water concentration with a tester.
  13. Over the next few days, adjust to the desired antifreeze/water mixture over the next several days. You'll likely have to **** out a little coolant mixture from the fill cap to create room for either the distilled water or the anit-freeze you'll be adding to adjust to the desired concentration. Sometimes I adjust by adding either water or antifreeze to the coolant- overflow tank which utimately mixes with the engine coolant;
  14. Don't forget to add collant and/or water to the coolant overflow tank.
Mar 28, 2009 | 2002 Mitsubishi Lancer
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Abbott Laboratories CELL-DYN 1700 Hematology Analyzer Logo
Top Abbott Laboratories Science & Laboratory Experts
William McMath
Tom Chichester
Are you an Abbott Laboratories Science and Laboratory Expert? Answer questions, earn points and help others
