My Luxor 16855 is stuck on analogue menu and i cannot access IDTV MENU
Lost signal tried to retune with IDTV MENU made the mistake of searching for analogue channels now cannot access IDTV menu
  • 6 Answers
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
panchal643Ja
  • 243 Answers
SOURCE: cannot access 'channel'' menu in samsung DTV menu
This is becouse you had done some Channel Child Lock first open all child lock than try to tune channel.Or possible that you are in some other input mode.select TV mode than you can try.
Posted on Jan 23, 2010
Obertelli
  • 3006 Answers
SOURCE: Samsung LE32N7 - Analogue channels ok - Freeview
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Posted on Sep 17, 2010
smarthome2
  • 1114 Answers
SOURCE: When I try to access
If you are accessing the tuning menu correctly; according to the TV's manual, try unplugging the set for half an hour or so, it will discharge all the capacitors and return to the initial setup page. If this does not work, there is a problem in the digital tuning board and would need to be serviced. Hope this helps.
Posted on Jun 01, 2011
SOURCE: i bought a TOSHIBA 32KV500B tv. At the Initial
I had this problem and searched the internet for hours looking for an answer and was given the initial same reply as this and it does not work. To solve this problem all you simply need to do is press source button on the controller followed by pressing the DTV/USB option. All your digital channels will come back to you and you will find the menu setup options you are looking for!!!
Posted on Jul 23, 2011
How do I retune a Luxor 16855 television
try to run auto scan to get other available channel on your location.
Jun 19, 2012 | Televison & Video
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
How do I adjust horizontal hold on Luxor 32-914-IDTV.
You have to enter its service menu window to adjust the picture position. Contact any experienced service technician. This is a skilled work.
Jun 08, 2012 | Televison & Video
My luxor Lux-32-914-IDTV has no sound coming from it
luxor lux-32-914-idtv, has a different shade line across screen two 3rds down screen
Jan 16, 2012 | Televison & Video
When I try to access the digital channels having watrched something on analogue TV get an error mesage 'error cannot acces digital services. Cannot access retune facility in tool menu, tried switching...
Jun 01, 2011 | Televison & Video
I cannot retune my samsung tv- model no LE37C53CF1W- COULD YOU ADVISE HOW TO RETUNE, mANY THANKS, Jim Lauder
Hi,Does the icon look like a large satellite dish?
Make sure your TV is on "TV" and not "DTV" before retuning.
To re-tune analogue channels:
I have a Samsung TV and that icon is not accessible from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
(on your remote, you should have a button with TV/DTV on it)
To re-tune analogue channels, if you want to re-tune digital channels, then look for the "D MENU" button on your remote. Press this then scroll down to the icon that looks like a large satellite and then on "Auto Store" This will re-tune your digital channels :0)
Take care and hope it helped.
May 28, 2011 | Televison & Video
I cant retune my proline tv/dvd combo as there is no retuning option in the limited menu.no option to reset on the controller either so have no signal now since swithover.how can i get it to reset anyone?
Some TVs brands - I believe Proline is one of them - cannot be retuned when you are in Digital mode. If you switch back to analogue mode, then press the menu button, the option to auto-scan should be available. Once you retune, switch back to digital mode.
Try this and post back if you need further assistance.
Please rate this solution if you find it helpful. Thanks.
Oct 20, 2010 | Televison & Video
I have a Daewoo DSL22V1WCD combined tv/dvd with built in freeview, our area is in the grasp of the digital switchover - everything I look at says I need to retune the tv - but this tv has various "sources"...
Press the DTV menu button (<<)
Press the Down arrow until you reach Settings
Press OK
Press the Down arrow until you reach Installation
Press OK
Press the Down arrow until you reach First Time Installation
Press OK
Aug 04, 2010 | Daewoo Televison & Video
Digital switchover
I also have the Sony IDTV KD-28DX4OU Digital TV.After the digital switchover I lost BBC1 and BBC2 despite retuning three times.
I contacted Digital switchover people (useless) and they passed the buck to Sony.I contacted Sony and they said they cannot fix the problem and that I should get a digital set top box. So the £650 I spent on integrated Digital TV has been wasted.If like me your cheesed off with this then I suggest you complain here
Sony United Kingdom Limited
Customer Information Centre (CSG)
Jays Close
Basingstoke
RG22 4SB
I have
Sep 30, 2009 | Sony FD Trinitron KV-28FQ75 28" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
