Question about GE Washing Machines
GE front load washer doesn't complete full cycle
The machine will not complete a wash cycle - specifically, it over fills with water, seems to skip the wash cycle completely, drains, but doesn't spin. Sometimes it will pause and the light will flash. I have checked the test mode for the problems and it states: -E22 : fill timeout -E23 : flood protect drain -E31 : drain timeout I have already emptied and checked the pump filter (it was clean). I also tried to run a T08, and T09, but it wouldn't do anything....any suggestions would be GREATLY appreciated! Thanks :)
SOURCE: F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
Posted on May 20, 2007
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
SOURCE: ariston awd121 washer will not complete wash cycle
I'm also having the same problem. I hate this machine!
Posted on Sep 22, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 113 Answers
SOURCE: GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Posted on Apr 24, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Is not spinning and not completing a full wash cycle
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Apr 23, 2011 | GE WBVH6240F Front Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine
full of sudsy soap after cycle complete, no water ???sounds as if your using the wrong detergent, youll NEED to use an HE detergent (low sudsing)specifically designed for use with front loading washers
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
GE Adora Front Load Washer
I went to the home depot site and they have various videos that explain about the washer and how it works. This made my understanding more clear as to how the washer works. Thanks!
Jul 25, 2008 | GE WSXH208A Front Load Washer
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Apr 28, 2008 | GE WSXH208A Front Load Washer
Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
