Question about SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry
Signal lights dont work
I have a 1992 dodge caravan and sometimes my signal lights work some times they dont but when they do work the indicator light work. when they dont the indicator light does not work i checked teh fuses they are good
    Sergeant:
    Champion:
  • 318 Answers
Flasher unit could be faulty,,,look near the fuse box,,easy to replace.
Posted on Jan 19, 2009
2000 dodge caravan turn signal dont work
I would check the fuse and for power at the turn signal switch.
Jul 18, 2012 | 2000 Dodge Caravan
My turn signals and hazard light dont work on my 1997 dodge caravan
check for a feed first to teh indicators and the hazard switch if you have a feed then renew the hazard light switch first as this switch if defective will stop all the indicator lights from working
Dec 10, 2010 | 2006 Dodge Caravan
Left turn signal stops working intermittently. sometimes it begins working again when I jiggle the lever. even this works with less frequency as time passes.
I recommend that you change the relay of the signal light or check the wire of the left signal light.Iin some cases you can find water inside of the signal light case, .
Oct 21, 2010 | 2000 Dodge Caravan
Starter relay location on a 1992 dodge caravan
Check along under hood on driverside fender area. Closest to windshield should be auto shut down, then next one toward front of van should be start relay. Probably a total or 4 or 5 there. Should be able to feel it click when starting, just to be sure no one mixed them up.
Sep 08, 2009 | Dodge Caravan Cars & Trucks
1992 Dodge Dakota signal lights quit working.
first check all fuses with a test light....and is that the only thing that quit working.... if power good sounds like turn switch it's self
Jun 23, 2009 | 1992 Dodge Caravan
Fuse box,, relays ?
Disconnect the battery for a minute or two and reconnect it. Sometimes the BCM (body control module) locks up.
Apr 14, 2009 | 2005 Dodge Caravan
Where is the heater and turn signal relay located 1992 caravan
These are seperate fuses and seperate turn signal falsher which evenually go into the same wiring. See my answer to your previous question. Good luck and hope it helps.
Jan 19, 2009 | 1992 Dodge Caravan
1992caravan turn signals, low beams, and heater motor do notwork
A) Faulty turn signal switch or circuit.
B) Broken dimmer switch or poor electrical connection.Could be relay also.
C) Unplug the electrical connector at the motor and use fused jumper wires to connect the fan motor directly to the battery. If the fan still doesn't work replace the motor. If fan works could be your relay.
Turn signals dont work headlights dont dim heater fan doesnt work
Did all these problems happen all at one time?? If so you may have a bad body ground. Try running a electrical wire from the (-) negative side of the battery to the body and see if this works. Be sure this wire is to a place with no paint as low voltage electricity will not flow through paint.
A). If not try replacing the turn signal flasher for the turn signal problem. This is usually the culprit and it's easiest and cheapest to replace. The turn signal flasher will be found under the driver side dash next to the hazard flasher. Turn the hazard flasher one to locate it. If you want try swapping the turn signal flasher with the hazard flasher to see if this fixes it. They are the same style flasher.
If this doesn't work you may a faulty turn signal switch or some wiring issues.
B). It could as simple as the head lights bulbs need to be replaced, it's rare but I have seen when both bulbs blew at or near the same time. If your able check the voltage at the head sockets.
C). Could be a bad blower motor or switch. I'm not sure if these models have a resistor block or not. The resister block controls the electrical current going to blower motor which controls the speed of the blower fan.
SimpleTech Signature Mini 160GB External USB 2.0 Hard Drive - Dark Blue Blueberry Logo
97 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
