Question about Pyle PD3000A Amplifier
Pyle pd3000a won't supply sound
I have power to the amp but no sound from speakers. Connections all good
Either your power supply is no good or your amp output stages are blown. Take your choice.
Mar 13, 2016 | PyleHome PT270AIU AM/FM Receiver - 300 W...
Unit has locked out in stanby. What is the process to reset. Locked out using remote.
I don't think you have a remote problem,but your unit need a hardware reset do it by professional. Basicly it reset your CPU and I bolive will start over
Mar 12, 2015 | Pyle PD3000A Amplifier
What cables will I need to properly install a pyle PADh212 1600w speaker cabinet with my pyle PD3000A 3000w receiver/ pre amp?
rca cables connectors and use an 1/2 inch jack like a guitar lead. that will do it. i have my sub woofer set up the same way via a bass rig head to receiver
Apr 08, 2014 | Audio Players & Recorders
Cant get sound using digital optical cable with pd3000
IT DOES NOT LOOK LIKE THE RECIEVER HAS A OPTICAL INPUT YOU WILL HAVE TO USE AV CABLE STERO RIGHT AND LEFT FROM TV TO RECIEVER THEN CONNECT BLUE RAY AND GAMING SYSTEMS WITH THE AV CABLES
Feb 19, 2014 | Pyle PD3000A Amplifier
Pyle pcau44 amp
A fuse is blown, check main supply fuse.
Dec 22, 2013 | Pyle Audio Players & Recorders
Pyle PCA4 power is up but no sound
Use a DMM Digital Multi Meter and test the speaker out put on the amps. while playing music threw amps un hook speakers. then do it.if there is no out put then it is an internal problem.
Feb 22, 2013 | Pyle PCA4 Amplifier
Pyle PLTAB8 Car Component System, Lights will not turn off. Help
Sounds like he did not wire a remote line from your radio to the amplifier, if he put a 12v from the battery to the amp and the remote spot on the amp then it will not turn off, you will need to either wore a toggle switch to the remote so you can turn it off manually or check the back of your radio for a remote line or splice a remote line from the accessory power supply on your radio so the amp will turn on when the radio is on
Feb 06, 2012 | Pyle PLTAB8 Car Component System
I am trying to hook up 3 kicker subs with a pyle 1400 watt amp in my 98 Eddie Bauer explorer and i am not sure how to do it because it has the stock amp in the back passenger quarter panel
First off, you won't be able to do this with a Pyle amp. Pyle amps are only 2 ohm stable (at best). When you do a 3 sub set up (assuming that they are all single 4 ohm voice coil), you will get either a 1.33 ohm load (way to low for that amp and will fry it quick), or you will get 12 ohms (hardly worth hooking up because of the lack of power).
Now say you have dual 4 ohm subs. You will still have the same problem going even lower than the 1.33 ohm or 6 ohms.
My recommendation is either do a 2 sub set up or get a better amp.
I know it's not what you want to hear, but it's true.
Aug 29, 2011 | Car Audio & Video
I have a 98 Sportster and the plmca 30. It says in the instructions the connector hooks up to most American bikes, but I can't find out where. Does the connector hook up directly to older American...
Your hooking up an amp to your sportster? and a 1998 at that. Before you do this, I would check on the specs of the amp, and find out how many amps system youll need to run this. Im not to sure that a 1998 XL's charging system puts out enough to support that. You may need to upgrade.
As far as the wiring goes, on ALL Harleys, the Orange wire with a White tracer is always your accessories wire. I usually hook up to that, somewhere under the tank, unless the directions advise otherwise, but, first, check your requirments and charging systems output.
May 10, 2011 | Pyle Pyle Plmca60 Cycle Series Motorcycle...
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Pyle PD3000A Amplifier Logo
27 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
