Question about Apple iBook G3 Mac Notebook
Unable to log in.
I am unable to log into the computer. I have 2 accounts set up, the Administrator and my son's. He attempted to log on several times as I did as well. We have restarted the computer several times and made sure the caps lock and num lock were not affecting the password entry process. I am looking how I can bypass the password process to reset the computer or any other helpful hints.
Thank you,
N
    Novelist:
  • 159 Answers
You don't say what operating system you're using, but on the premise you're running one of the three last versions:
http://support.apple.com/kb/HT1274
Posted on Jan 19, 2009
Cant log in on my computer
1. Is the computer connected to any domain network?
2. Are you facing this issue in Administrator account? Do you have other Administrator accounts enabled in the computer?
3. Have you made any changes to the computer prior to the issue?
Method 1:
Check if you are able to boot the computer in safe mode.
Step 1: Safe mode
Boot your computer in safe mode and check for the issue.
To start your computer in Safe modehttp://windows.microsoft.com/en-US/windows-vista/Start-your-computer-in-safe-mode
If you are unable to boot into Safe mode, please let us know.
Step 2:
Did you perform the system restore from the Windows Recovery Environment?
If not, I would suggest you to perform a system restore from the Windows Recovery Environment. Follow the steps from the provided article.
http://support.microsoft.com/kb/940765/en-us
Hope this helps!
--N
May 31, 2014 | Computers & Internet
Need the bios password on my gateway solo 9500
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
Once you've logged into the Administrator account open Control Panel and User Accounts.
Oct 04, 2011 | Axiom Audio Axiom 40GB for Gateway Solo...
Has hdd password that i cant reminber any way to remove it
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Sep 24, 2011 | Computers & Internet
I DO NOT KNOW THE PASSWORD OR USERNAME FOR MY QWEST P5000Z MODEM . dONT KNOW WHERE TO START TO FIND IT OR CHANGE IT? PLEASE HELP! THANKS- AMY : )
what operating system ? and what type and brand of computer desktop laptop ?
Reboot the computer into Safe Mode.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
hope this helps
Sep 22, 2011 | Computers & Internet
I want to reset my computer password
When you boot up to the log in screen type in administrator to log in if you cant log in
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
or
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Dec 25, 2010 | E-Machines eMachines Desktop PC
Windows xp pro logon error message "unable to log you on because your account has been locked out"
Hey!
If your computer is a part of a business network, you should contact the network administrator so he/she would setup or reconfigure your user account correctly.
If it's a home computer, you'll have to log on as Administrator to unlock your account. To do so:
  1. Click Start -> Log off (user name).
  2. Press Ctrl+Alt+Delete twice.
  3. Type Administrator in the user name and fill in the Administrator account's password. Leave blank if there isn't any.
  4. Once logged in, Click Start -> Run...
  5. Type in: LUSRMGR.MSC and click OK.
  6. Double-click on Users folder.
  7. Double-click on your locked user account.
  8. Uncheck "Account is disabled" and click OK.
  9. Close "Local Users and Groups" window.
  10. Click Start -> Log off Administrator.
  11. Login to your user account!
Note: If you don't have access to the Administrator account (because you don't have the password), please do tell and I'll give you the instructions on how to reset it.
GOOD LUCK!
Pelu.
Apr 06, 2010 | Microsoft Windows XP Professional
I bought a computer and I can't even get into it because it is password protected is there something I can do?
yes if the password is unde bois you can clear the cmos hardwar if it is under windows you can use hierin to remove the password it is easy contact me with details and i will tell you how to deal with the passswrod issue you have
Oct 26, 2009 | HP Computers & Internet
Trying to login to my account,it's not accepting my login,or anything
If you mean trying to log in to your computer using your Username and Password then I suggest trying to log in to the Administrator account and change your passowrd for the account you are unable to log in to
Once you are in the administrators account, check that there are no limitations on your account that prohibits you from logging in. To do this right click on My Computer and click Manage. On the computer management window click on Local Users and Groups, click on Users folder.
Where your username is right click and click on Properties. Make sure none of the boxes are ticked (especially Account is disabled - If it is untick) and tick Password never expires and click on Apply
Log out of Administrator Account and log in to your own
Oct 22, 2009 | Computers & Internet
Unable to log in Windows XP
Hi
My name is Sydney, you should try to log in as administrator without entering the password that is if when installing the operating system the admin password was not set, in most cases when you switch on your computer the administrator use is not shown. So what you do is press ctrl+alt+del+del, you will have to hold ctrl+alt while you press delete twice. Then type under username administrator and on password leave it blank. if this does not work try entering your administrator password.
If this does not work, restart your computer. and go into safe mode, you can try to press F8, or F2 or Esc, depending on the make of your computer, this should be done before it shows the windows logo, at the time it is checking your drives.
in some cases you may have a problem with your keyboard, maybe some keys are sticking so you can try to use another keyboard and see if you get the same results.
if the above does not work, check to see if you computer has a recovery cd you can put this in your cd drive then restart the machine. it should ask you to press any key to boot from the cd, press any key then follow the on screen instructions. NOTE that with this process you may loose all you documents and your computer will restored to the way it was the first time you bought it.
I hope this solves your problem, but if the problem persists please do not hesitate to contact us again.
Kind regards
Sydney
Feb 10, 2009 | Apple iBook G3 Mac Notebook
I can't log in
The password can be reset by booting from your OS X installer CD and choosing “Reset Password” from the Installer Menu.
Here a link to the Apple website that details how to do this.
Jan 19, 2009 | Apple iBook G3 Mac Notebook
Apple iBook G3 Mac Notebook Logo
177 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
