Question about Air Tools & Compressors
Nikota 2hp air compressor twin tank need crank case cover
thepot
  • 188 Answers
SOURCE: I have a small Hitachi 2HP compressor,oil lube w/twin green tanks
the air pressure switch is gone, get a professonal 2 fix it just incase anything should go wrong
Posted on Nov 08, 2009
SOURCE: Need manual for a Kawasaki model 840703 5gal 3hp
I called 1 800 590-3723 and they are e-mailing a manual to me. For my model (3HP twin tank) they said 10W30 or 5W30.
Posted on Feb 26, 2010
heatman101
  • 43501 Answers
SOURCE: I installed a new pressure
If you are kicking the breaker when you turn it on, then you have a short somewhere....
The easiest way for you to find that problem will be for you to use an OHM meter and trace down the cause of the short...
With an OHM meter you be able to get to the bottom of the problem rather quickly...
Then fix the cause of the problem....
heatman101
Posted on Nov 25, 2010
ftw1952
  • 10319 Answers
SOURCE: I need a seal for
call the closest Harbor Freight store since they sell this model or check the store on line
They should know wre to get replacement parts for you
Posted on Mar 22, 2011
  • 47 Answers
SOURCE: I need a seal for central pneumatic twin tank 2hp
Try this link......http://fitness.manualsonline.com/ex/mfg/headline/m/harbor_freight_tools/type/product_problem/
Posted on Mar 24, 2011
I have a mech power 2hp twin tank air compressor..m90002. It only generates to 120psi then shuts off. Can I get it to go up to 150psi? If so how? Thanks
It is what the max pressure is to handle before the safety valve can have if it concept is for 10 bar then you have a 10.5 bar safety valve or if its 8 bar its 8. . 8.5 look at the tank itself its in most case there you can read what it can handle.
May 18, 2016 | Air Tools & Compressors
When I plug my Magnum 2 HP 5 gallon compressor in, it blows out oil out of the red plug that you put oil in
Could be you are filling it too much, such as to the top of the oil hole instead of the bottom of the hole. I suggest you check the manual.
Perhaps the compressor isn't level or perhaps the crankcase breather is blocked or not working properly or perhaps there is too much piston blow-by for the breather to cope with.
Feb 03, 2015 | Magnum Air Tools & Compressors
Compressors fell on its side while running, when I noticed it was because I had lost air pressure. It runs, it's sounds alright button pressure in the the tank and the intake is blowing air out instead of...
You will most likely need to remove the head and check the reed valves. Sounds like the intake reed is leaking or pressure side is leaking back into the intake thru bad gasket. If reed is broken, you can make one from old feeler gauge, just cut to size. Good luck
Sep 04, 2013 | Eagle 2HP 4.2 Gal. Direct Drive Twin Stack...
My twin tank 2hp comp will run but pressure wont build up pass 20 lbs.
If the motor is working OK but pressure won't go over 20psi you may have an air leak but most probably have damaged piston rings or cylinder or the valve plate is damaged. Check to make sure the tank drain valve isn't open or that you don't have leaks in any of the air lines. If that's OK, you will have to remove the head from the cylinder to check the valve plate and piston/cylinder assembly. The reeds on the valve plate should be flat and not overly discolored (black or blued) from heat. If they are they can warp or get brittle and break. Since your compressor is oil lubricated it is rare for the piston/rings/cylinder to get damaged unless it's run with no oil so check those areas for scoring or damage like broken rings. Replace whatever is damaged and keep the oil full.
Sep 18, 2012 | Dewalt D55151 2HP 4G TWIN COMPRESSOR
I need a seal for central pneumatic twin tank 2hp iteam 42321. Where can I get it online?
Mar 24, 2011 | Air Tools & Compressors
I have a 2hp twin tank IR compressor It will not fill more than about 20psi. And there is a spring loaded pressure cable on the outlet side of the head that doesn't close sir leaks from here as long...
From your description, it sounds like your problem is in the cylinder head(s). The fact that the air leak stops as soon as the compressor stops rules out the check valve at the tank. You will have to remove the head(s) and physically inspect the reed valves. Even one broken reed valve on the exhaust side can cause the air to be "cycled" inside the head, therefore not allowing it to go to the tank. I hope this is helpful to solving he problem. Please contact us again if the problem still recurrs.
Jan 04, 2011 | Ingersoll Rand Air Tools & Compressors
Nov 08, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
