Question about Whirlpool Duet GHW9150P Front Load Washer
How to access test mode on kenmore washer 110.49962602
How to put machine into diagnostics mode
2 Suggested Answers
SOURCE: C45072 Kenmore washer will not start. Did one
I've been going crazy with this too. Turns out all you have to do is hold down the "options" & "select" buttons at the same time until the "lock light" (the light just above the "pause/cancel" button) turns off. I guess that's why there is a line under the option/select buttons that have a lock symbol connecting the two.
Cheers!
Posted on Jun 23, 2009
F1 error code
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My machine says f1 constantly it wont finish the load i here my machine might be a recall
Aug 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does f1 mean on a cabrio washer
Apr 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I put a Kenmore 417.44092500 into test mode
Each one of these washers comes with a technical datra sheet inside. The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. Some model washers have two versions of diagnostics that include SHORT and LONG step modes to include simple and more advanced troubleshooting procedures. Since the procedures for entering diagnostics differs between models, it is recommended that you refer to this tech sheet to ensure you perform the procedures correctly.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Apr 07, 2010 | Kenmore Energy Star 44092 Front Load...
My washer comes up with f1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(@#$%
Apr 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our washer flashes acode f1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#%^
Mar 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code f1/f2 --washer turns off
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*$%^
Mar 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code F1
Jan 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When washer starts get F1 error
Nov 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washing machine keeps flashing F1?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Mar 28, 2009 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
