Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Noise and shake in washer model# MHW2000AWW
Does not spin close out very well, and sounds like a aloud airplane when it spins
4 Suggested Answers
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
  • 401 Answers
SOURCE: my washer sounds like an airplane taking off when
its probebly the main bearing. disconect the power and remove the back. then slide the belt off the big pulley. if you see alot of brown splatter you know its the bearing.if not with the belt removed go to the front and open the door spin the drum fast, if it makes the same noise its the rear bearing.
Posted on Jan 15, 2010
SOURCE: Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Posted on Feb 16, 2010
It making aloud noise when spinning dry
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
During the spin cycles, the machine makes noise, almost like an airplane ready for take off. It also shakes and "walks". As the spinning increases, the noise and shaking increases. The shaking...
Not an expert but had identical symptoms. Problem was the loosening of the nut 27mm on the main pully. Simply remove lower back panel (16- torx 20 screws ) and tighten same.
If this does not hold over time, the pully hub has been damaged, and a shim, ( shopmade washer ) may solve problem. Remove belt, and pully, look for damage, and install thin shim, so that the nut will not bottem out on bolt before tightening on the pully hub. Good Luck, Lee
Mar 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My front loading washer makes aloud noise and shakes terrible when it spins at mediun or high speed. model ifw7200tw
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Nov 26, 2010 | Washing Machines
Maytag Neptuen Washer makes loud noise when spinning. Sounds like an airplane taking off.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.Get the spin bearing and motor checked.Replace the faulty. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Maytag Neptune Washer
My washer makes aloud noise when on the spin cycle. HELP I Started a load of laundry and it washed fine until the spin cycle. It started making a terrible noise.
sounds like the bearings have worn out at the back,to check this open door and with your hand lift chrome inner drum up and down if you feel like a knocking noise then its bearings,
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sounds like an airplane taking off!
check your drive block under your agitator if metal shavings replace
Nov 08, 2008 | Kenmore 22422 Top Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
