Question about Hotpoint WML520 Washing Machine
Programme settings hotpoint aquarius wml520
It is stuck on number 4 and will not go to any other setting
SOURCE: HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Posted on Feb 07, 2008
  • 3 Answers
SOURCE: Hotpoint Aquarius WD440
u might have a blockage in the drainpipe. hope it helps. good luck!
Posted on Jun 29, 2008
ghappliances
  • 126 Answers
SOURCE: hotpoint bwm129 gets stuck mid cycle and dial does not move round
YOU NEED TO ESTABLISH IF YOU ARE USING A HOT CYCLE IF THAT IS SO YOU MIGHT HAVE E PROBLEM WHERE THE ELEMENT IS NOT COMING ON THEREFORE THE THERMOSTAT WILL NOT FUNCTION RESULTING IN THE TIMER REMAINING STILL.YOU NEED TO CHECK THE ELEMENT IF THATS THE CASE.IF YOU ARE USING THE COLD CYCLE AND IT IS STUCK ON THE SAME POSITION FOR A LONG TIME YOU MIGHT HAVE A FAULTY TIMER BEST YOU HAVE IT REPLACED IF THAT IS THE CAUSE.LET ME NO IF YOU NEED ANY MORE ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
beltronic205
  • 1456 Answers
SOURCE: Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Posted on Sep 29, 2009
  • 160 Answers
SOURCE: how do I remove the powder draw from the aquarius
1. Extend the dispenser drawer until the stop is reached.
2. Press the locking tab located in the centre rear of the drawer and pull the drawer out.
Posted on Mar 21, 2010
Programme settings hotpoint aquarius1200
download your instr.manual from www.fitness.manualsonline.com ro www.retrevo.com for free and proceed with the details.
God bless you
Jul 18, 2012 | Hotpoint Washing Machines
My hotpoint aquarius will not spin
If the inlet cycle proceeds and then activated the wash after the water level is detected then the program cycle is intact. However if the second spin does not start, you need to check if there is voltage to the motor at this time , if not the control panel memory to the processor can be corrupt or the IC damaged.
Jul 03, 2012 | Hotpoint WML520 Washing Machine
Wml520 programme panel is flashing
Remove power for some time, open the panel and check the connectors and contacts. When the power is switched on , press down the start/stop button.If the fault does not clear the suspect can be the controller board.
Jul 03, 2012 | Hotpoint Washing Machines
How do I remove the powder draw from the aquarius wml520, please?
Mar 19, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WML520 Washing Machine Logo
64 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
